1969 Charger trim #1457509
06/24/13 01:56 PM
06/24/13 01:56 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
There is a plastic cover that goes on the body as you get in the rear seat to cover the welded seam as you get in the rear seat that goes down and ends under the door still.. I have two long pieces of this plastic pieces that looks the same and looks like it may go along the roof line also. Can some one tell me if there is a long piece that goes from the dash to the side window to help hold the head liner in place.... Thanks
Re: 1969 Charger trim [Re: JohnH] #1457510
06/24/13 04:11 PM
06/24/13 04:11 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
it uses a long steel piece that snaps on & the has a couple of screws
also on the headliner there are some very small clips to hold it on the roof edge.
Re: 1969 Charger trim [Re: JohnH] #1457511
06/24/13 10:09 PM
06/24/13 10:09 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
If you are referring to the "windlace" that is on the quarters (and is also color coded to the interior color)thats the only location for it....
1MYTGTX
Re: 1969 Charger trim [Re: 1MYTGTX] #1457512
06/25/13 10:04 AM
06/25/13 10:04 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Thanks for the reply's. Yes it is the one on the 1/4 panel, I took this car apart about 12 years ago and I have two long pieces that looked like it went along the roof rail to hold the head liner up,, I know how it goes now, thanks to the reply's...
