Electric Fuel Pump Recommendations #1457432
06/24/13 08:02 AM
06/24/13 08:02 AM
anytown
440dodge440 Offline OP
anytown
I have a Holley Blue pump on my car that I now have to tap with a hammer to get running. I did some searching and apparently this is a common problem. I'm comsidering the Mallory 140 series or the Edelbrock (Jeg's) Quiet Pump. Does anyone know if these pumps are worthwhile, or have any other recommendations.
Re: Electric Fuel Pump Recommendations [Re: 440dodge440] #1457433
06/24/13 02:48 PM
06/24/13 02:48 PM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
I have had great luck with the Carter pumps. Super reliable and alot quieter than the Holly.
This pump has about same flow rate and psi as the Holly.
Carter P4601HP Carter Competition Series Electric Fuel Pumps
Re: Electric Fuel Pump Recommendations [Re: crazyjjk] #1457434
06/24/13 07:03 PM
06/24/13 07:03 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
walbro gsl 392.
summit. 100 bucks.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Electric Fuel Pump Recommendations [Re: mopardude318] #1457435
06/24/13 09:17 PM
06/24/13 09:17 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Whats your app/need ??
I am truckless..
Re: Electric Fuel Pump Recommendations [Re: 340SHORTY] #1457436
06/25/13 08:14 AM
06/25/13 08:14 AM
anytown
anytown
Thanks for the replies. It's for a mildly built 440 with a 750DP...The blue pump supplied fuel fine...As of now, a mechanical pump would work, but I want the electric for filling the bowls when the car sits for long periods and for future build additions.
Re: Electric Fuel Pump Recommendations [Re: 440dodge440] #1457437
06/25/13 08:43 AM
06/25/13 08:43 AM
tboomer Offline
tboomer  Offline
Check out a Firecore pump from Rick Gorski on the board here...I have one and it is feeding 512 Cubic inches!
Re: Electric Fuel Pump Recommendations [Re: tboomer] #1457438
06/25/13 01:13 PM
06/25/13 01:13 PM
dogdays Offline
dogdays  Offline
Carter Street Pump, P4070, no need for a regulator, will pump enough gas for a really long time.
R.
Re: Electric Fuel Pump Recommendations [Re: dogdays] #1457439
06/25/13 01:40 PM
06/25/13 01:40 PM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
R.
I agree another great choice. The only reason I recommended the other carter pump is that it was approximately the same PSI as the Holly pump he was replacing.
