Power steering pump #1456997
06/23/13 01:02 AM
06/23/13 01:02 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
in restoring a 70 Runner...I'm using a sagniaw pump. What size is the pulley. I have 3 pumps with 3 different pulleys.(440-6 motor) Any help will be greatly appreciated. Thanks!----6" 6-3/4" and 7" ----rear gear ratio is 4:10
Re: Power steering pump [Re: Roadrunner440-6] #1456998
06/25/13 08:58 PM
06/25/13 08:58 PM
Didn't get any replies the first time around.......In theory...with 4:10s I probably would need the largest pulley available...since the rpm's will be considerably higher and working that pump that much harder. However... I'm guessing that's why mopar put the power steering cooler on the trac pak and super trac pak cars due to their lower gear ratio. If anyone can measure their pulley on a 440-6 ----4:10 geared car.....that would be greatly appreciated.-----------------------
Re: Power steering pump [Re: Roadrunner440-6] #1456999
06/25/13 10:04 PM
06/25/13 10:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
How's 7" !
