Proper transmission storage (727)
#1456757
06/22/13 09:27 PM
06/22/13 09:27 PM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I know engines require a special method for storing, what about transmissions. I have a slightly used 727 that needs nothing and I want to store it for a couple years. Drain it, don't drain it? Want to keep it in good working order while being stored. Thanks.
Facts are stubborn things.
Re: Proper transmission storage (727)
[Re: larrymopar360]
#1456760
06/24/13 03:13 PM
06/24/13 03:13 PM
RapidRobert
best would be to store it in a dry heated environment at a steady temp. temp fluctuations that drop below the dew point make moisture condense & form on metal. Wrap it in several layers of thick garbage bags just for the oil drippings but keep the end open so as to not trap moisture inside then put it in a wooden box & paint the box nice then use it in your living room as a foot rest or coffee table. When you ressurect it it'll look & function as good as the day it went in (ex for the seals) just like an artifact coming out of the Egyptian pyramids with the dry air there
[Re: RapidRobert]
#1456761
06/24/13 11:31 PM
06/24/13 11:31 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Robert, if you knew what my living room looked like you'd know it'd fit right in without the box I gotta figure this out. Hate to sell it because it only has about 10K on it and cost me a grand. Super firm shifting HD unit, but I just don't have a car to use it in right now. May just end up trying craigslist since it's too big to ship, but I'd really like to keep it until I need it. Thanks.
[Re: dogdays]
#1456764
06/25/13 03:04 PM
06/25/13 03:04 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Do you guys store yours setting on the pan, or standing up with the bellhousing as the base.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1456765
06/25/13 04:25 PM
06/25/13 04:25 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I was thinking of using an old tire to sit it on.
