roadrunner horn #1456573
06/22/13 03:15 PM
06/22/13 03:15 PM
btomasko Offline OP
btomasko  Offline OP
How do you test and adjust the road runner horn,this is an after market horn cant seem to get it to work,,it goes from high to low and then sometimes nothing,need help. thanks
Re: roadrunner horn [Re: btomasko] #1456574
06/22/13 04:09 PM
06/22/13 04:09 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
The adjuster on my after market RR horn doesn't seem to do anything. The adjuster worked fine on the stock RR horn. I remember having to make a tool to adjust it, I think the screw head had 7 points.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
