floating puiston pin oiling holes on rod small end #1456568
06/22/13 02:35 PM
06/22/13 02:35 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I was wondering why is it that when you modify OEM rods for using floating pins, you have to drill a hole on center on the very tip of the rods small end (12 o clock)....
whereas on the new eagle H beam rods you will see they have 2 holes at 5 oclock and 7 oclock.
Why the different locations?
Re: floating puiston pin oiling holes on rod small end [Re: domingo] #1456569
06/22/13 03:18 PM
06/22/13 03:18 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My best wild assed guess.....they pick up more splash in this position.
Some time ago , I had a set of big block rods bushed for a .990 pin and drilled for oiling by a well known shop up here. He came in at 6:00 diagonally to roughly the center of the bushing.
Works on paper.
Re: floating piston pin oiling holes on rod small end [Re: tubtar] #1456570
06/23/13 02:16 AM
06/23/13 02:16 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'd put a single hole at the top of the pin. From my modeling of a Manley I-beam Hemi rod, the 4 and 8 O'clock positions have higher stress under tension. Under compression, the force is down on the pin, so less stress there again.
Floyd Lippencott IV
Re: floating piston pin oiling holes on rod small end [Re: mr_340] #1456571
06/23/13 02:41 AM
06/23/13 02:41 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I have done it TWO TIMES in my engine building experience .....12 oclock HIGH for me too !!
....NO bushings ... just steel to steel.
Re: floating piston pin oiling holes on rod small end [Re: dOoC] #1456572
06/23/13 01:03 PM
06/23/13 01:03 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the replies,,,,
Yes, I also have mine done at 12 o clock when I reuse stock rods. I always use the bronze bushing though...
