Hemi exhuast manifold heat riser leaking?
#1456440
06/22/13 08:47 AM
06/22/13 08:47 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
leaking from the stem, is there a quick fix, or do i need to change the whole set up?
Hell Hath No Fury Like Mine
Re: Hemi exhuast manifold heat riser leaking?
[Re: Dodgem]
#1456442
06/22/13 01:26 PM
06/22/13 01:26 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
aside from buying the whole heat riser kit. there's nothing to say fix the stem?
[Re: sixpacksteve]
#1456443
06/22/13 03:26 PM
06/22/13 03:26 PM
Posts: 1,383 Az
69hemibeep
Az
The stem has to be removed to drill the manifold for the bushings. The internal flap is welded to the stem so a small grinder is needed to remove the flap. Needless to say the manifold is coming out to do this.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#1456444
06/22/13 11:12 PM
06/22/13 11:12 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i figured as much, hoping there was something magical! thanks
