Engine troubleshooting help request for 360 #1455953
06/21/13 08:45 AM
06/21/13 08:45 AM
Nampa, Idaho
W
Wyle E Coyote Offline OP
W
Nampa, Idaho
I'm either about to lose my mind or my hair over this one. I need some gurus to help me sort this thing out. About a year ago I swapped in a '73 vintage 360 from a Class C Motorhome into my IH Scout 2. It was a great running 90k mile motor and trans, and the install was a snap really. Even with the problems I'm about to lay out, it still idles as sweet as a 90k mile motor should. I meticulously went through the wiring to make the Chrysler alternator, voltage regulator and electronic ignition, work with the GM style wiring the Scout has, including an ammeter bypass.. After I started to drive it, I noticed a little bit of a surge and sputter during cruise. I bet on a bad carb, and bought a kit. It didn't seem to help.
So I looked into the ignition. One piece at a time I go after it. Reman distributor, new module and coil, and even a new ignition switch. Nada. So now I replace the spark plugs, check the cap, rotor and wires, and find,..... still nothing. Then I start to think vacuum leak. I sprayed starting fluid everywhere, nothing. I replaced a couple of small vacuum lines that might be an issue,.. nada. No change without the brake booster attached even!
Then a friend suggested grounds. I add a bunch of grounds and clean up the ones I have. Still nothing. So it has been mostly parked. I had to drive it the past couple of days, so I filled it up with fresh gas and took off. It's even worse. So much so that it misfires randomly out the exhaust, especially on deceleration!
What am I missing? Please help, I haven't much sanity left. Thanks!!
25 Dodge Roadster
66 D100 440/727 (on 72 D100 chassis)
67 W200 360/727
72 IH TravelAll 1110 4x4 345/727/NP205
76 Scout 2 360/727/D20
'08 Dakota SLT Quad Cab 4wd 4.7L
Re: Engine troubleshooting help request for 360 [Re: Wyle E Coyote] #1455954
06/21/13 09:40 AM
06/21/13 09:40 AM
U.P. ,MI.
P
plumcuda Offline
plumcuda  Offline
P
U.P. ,MI.
Check compression?
Re: Engine troubleshooting help request for 360 [Re: Wyle E Coyote] #1455955
06/21/13 09:45 AM
06/21/13 09:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds lean to me, ethanol gas makes all these old motors run lean if it's a carburetor and will cause surging and misfires under load.
Re: Engine troubleshooting help request for 360 [Re: Wyle E Coyote] #1455956
06/21/13 09:59 AM
06/21/13 09:59 AM
it ran great before & after the swap it doesn't & there were no changes to the eng other than wiring adaptations to make it fit the GM system? Measure the voltage you get at the coil and ECU. How long was it sitting until it was swapped? It might be an undetected vac leak on the bottom of the intake gasket sides that wont show up with the spray. I was thinking rotor phasing but that wouldn't change from sitting & you swapped dists which a different one may have better or worse phasing but you said no change from that but the phasing may be borderline in both dists. On tough cases I go back to basics & I'd do a compression test which'll tell you if your long block is healthy & then cap the vac adv which will alter (rotor) phasing & see if that makes it better/worse or no change. After that just me I'd change the intake gaskets & use the black fiber Felpro ones (printoseal?) with the blue borders around the port openings with some Permatex "high tack" #MA99 iirc, the red stuff in the blue spray can. If the long block is healthy then that only leaves the intake the carb (lean) & the ign. Holler how it goes. EDIT You might also check how much slop is in the timing chain: with a 1&1/4" socket breaker bar turn the crank CCW a bit to take the slack out then slowly go back CW & have a helper tell you when the dist rotor starts to move & note how many degrees on the balancer you have to turn it till the rotor just makes contact/starts to move. MORE EDIT What Challenger said might jet up & see what happens & that'd be fast/easy to do. Thermoquad I'm assuming? Could block the metering rod tree up & retry it & see what being on the power circuit does for it
Re: Engine troubleshooting help request for 360 [Re: RapidRobert] #1455957
06/21/13 12:35 PM
06/21/13 12:35 PM
dogdays Offline
dogdays  Offline
Small piece of dirt in a metering jet could cause all those problems. It has happened to me.
R.
Re: Engine troubleshooting help request for 360 [Re: dogdays] #1455958
06/21/13 03:54 PM
06/21/13 03:54 PM
P
Paul_Fancsali Offline
P
If it still has the Holley 2bbl factory carb you can bet it is warped from the air cleaner stud pulling on the body. If that is the case take carb apart and check upper flanges with a good straight edge Next is the mopar elec ignition if you are using it. They are very sensitive to ground if you have a 4 prong ballast resistor make sure you have the right box, frankly I would go pertonix and scrap it. 60s that year are very prone to bad valve seals and to plugged manifold heat passages, intakes love to blow out and check 5-7 for blown head gasket it won't over heat but will give you misery. Check back of head on driver side
Re: Engine troubleshooting help request for 360 [Re: RapidRobert] #1455959
06/23/13 06:54 PM
06/23/13 06:54 PM
Nampa, Idaho
W
W
Nampa, Idaho
I see I left out a few details. This truck is running the stock Carter 2 BBL right now. When I tested the engine before buying, it fired right up, cold. It only seemed to have an issue with the accelerator circuit, so I assumed the problem was a bad accelerator pump, since motorhomes typically sit a lot. Idles steady and smooth as could be. The motor was pulled in the summer time, and went straight to my engine stand in the garage. And I went about installing it that next spring, so I don't imagine any issues will arise from that. About the only time that it runs right aside from idle is when I'm deep into it. It seems to quit these problems, but I've only done that test a time or two. While installing the engine I found the timing chain was bad, so it was replaced with a new double roller at that time. I'd be surprised if it was a rotor phasing problem, because the rebuilt distributor is a Cardone unit, the kind you usually get at most part stores. But its something to keep in mind I guess. I haven't done a compression check because of how nice it runs at idle, and because it doesn't burn or leak any oil. But it's worth a shot I suppose.
Now I'm wondering if there's a way for the intake to have a crack or something in it, where it could act this way. I've never had a cracked intake, but it did come from a B300 motorhome chassis. And those earlier vans were known to crack and warp exhaust manifolds due to high underhood temperatures. I suppose a cracked intake isn't out of the realm of possibility. I'm considering an Edelbrock Performer intake and dropping the ThermoQuad that I have onto it. But the TQ is an untested unit I got from a pick-up in the bone yard about a year ago. I really would rather pinpoint the drivability issue I have now, before I go about adding more. But at this point, maybe it wouldn't hurt?
25 Dodge Roadster
67 W200 360/727
Re: Engine troubleshooting help request for 360 [Re: Wyle E Coyote] #1455960
06/23/13 10:38 PM
06/23/13 10:38 PM
Just me, to k.i.s.s. I'd try another carb on there
