From the website FAQ
http://www.nhra.com/contacts/tech_faq.htmlI have a street car that I occasionally run at the strip. I've relocated the battery to the rear. What else do I need?
Any car with a relocated battery must be equipped with a master electrical cutoff, capable of stopping all electrical functions including ignition (
must shut the engine off, as well as fuel pumps, etc .). The switch must be located on
the rear of the vehicle , with the
"off" position clearly marked . If the switch is of a "push / pull" type, then "push" must be the motion that shuts off the switch, and
plastic or "keyed" typed switches are prohibited .
Also, the battery must be completely sealed from the driver and/or driver compartment. This means a metal bulkhead must separate the trunk from the driver compartment, or the battery must be located in a sealed, metal box constructed of minimum .024 inch steel or .032 inch aluminum, or in an NHRA accepted plastic box. In cars with a conventional trunk, metal can simply be installed behind the rear seat and under the package tray to effectively seal the battery off from the driver. In a hatchback type vehicle the battery box is usually the easiest solution, since the alternative is to fabricate a bulkhead which seals to the hatch when closed. At present, Moroso is the only company which offers an NHRA accepted plastic battery box, part number 74050.
