340 TA engine #'s #1455783
06/20/13 07:51 PM
06/20/13 07:51 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
"Supposedly" my Dart has a 340TA engine in it. I have not looked to see that this is true.
Where exactly is the number stamped on the block and is there anything that confirms it is indeed a TA block?
Driving modern convenience in classic beauty
Re: 340 TA engine #'s [Re: Darius] #1455784
06/20/13 07:59 PM
06/20/13 07:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It is CAST into the side of the block 3577130TA-340
Re: 340 TA engine #'s [Re: ScottSmith_Harms] #1455785
06/20/13 09:06 PM
06/20/13 09:06 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Thanks Scott
Re: 340 TA engine #'s [Re: Darius] #1455786
06/20/13 09:30 PM
06/20/13 09:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
..... but "T/A" blocks were used and built as 4bbl engines in 1971 (& maybe after T/A & AAR production in '70???). So, you'd have to confirm the partial VIN# on the block you have was built during T/A & AAR production. Is the info on the front face of the block below driver's side head different 6bbl vs. 4bbl?
Re: 340 TA engine #'s [Re: 6bblgt] #1455787
06/20/13 09:55 PM
06/20/13 09:55 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I finally found it and it is definitely NOT a TA block! Serial # starts with a 278xxx .The casting date was 06-70
Re: 340 TA engine #'s [Re: 6bblgt] #1455788
06/21/13 04:16 AM
06/21/13 04:16 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
whether they were used in a pickup truck or a VW..the TA block will have the partnumber and TA cast into the block that is shown above.
Tony
70 AARCuda Vitamin C
