Dash Mounted Tach #145576
11/04/08 03:15 PM
11/04/08 03:15 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
I have a mechanical tach that I want to mount to the dash. I've alreadt figured I would need a right habd adapter and I already have the cable. Any suggestions on mounting a mechnaical tach? pictures?
Re: Dash Mounted Tach [Re: dart4forte] #145577
11/04/08 03:19 PM
11/04/08 03:19 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Who's mechanical tach?
Well, your speedo is most likely mechanical right?
You only need room for the cable to run kink free.
Why the mechanical tach if I might ask?
Re: Dash Mounted Tach [Re: Dart 340] #145578
11/04/08 05:39 PM
11/04/08 05:39 PM
Mesa, Arizona
Mesa, Arizona
Stewart Warner mechanical tach, cable will be routed from engine compartment through the antenna cable access up through the heater grill into the tach. Old school and nostalgia are the main reasons
Re: Dash Mounted Tach [Re: dart4forte] #145579
11/04/08 06:17 PM
11/04/08 06:17 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
That's kind of what I figured.
Like a speedo, as long as you keep the bends
gentle it should be fine.
Re: Dash Mounted Tach [Re: dart4forte] #145580
11/04/08 07:57 PM
11/04/08 07:57 PM
Mesa, Arizona
Mesa, Arizona
