Re: Dodge Dakota injector up grade ??
[Re: swepty]
#145569
11/05/08 02:13 AM
11/05/08 02:13 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Better mpg and hp smoother idle. The ford injectors have way better atomization charicturistics. If you have had the heads off a magnum motor after they have been ran for a few miles you can see the injector shoots a solid stream of fuel right up against the side of the port and the fuel runs down the bottom of the port and never has a chance to get atomized. The ford injector has 4 nozzles pointing in different directions but similar flow numbers (the 5.4 is actually a little more flow and I think the 4.6 flows a little less). I had 4.6 injectors on a 95 5.9 and it seemed to smoothe it out and help MPG but hurt power a tad, the 5.4 injectors put the power back up how it was before but it still ran smoother and mpg was better. The plug ins were the same for quite a few years but I don't know how the new plug ins are shaped on the newer skinny injectors.
The accel injectors have an even better spray patter it is a cone and no streams.
[Re: swepty]
#145572
11/05/08 10:29 AM
11/05/08 10:29 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I have a 92 5.2, and it has a lot of power, but always would like more, and if I can get better mpg while doing it, then that's cool too. So you would suggest using the 5.4l injectors in an application like mine with a 92 5.2, I also have a 95 5.2 would they work for that too?
If you are still running the stock computer I have a extra performance computer that is a big improvement.My 93 5.2 Sport 2WD regular cab with 2.5 exhaust and 3.55 sure grip will smoke just about any stock 5.0 Mustang.
[Re: 62maxwgn]
#145573
11/12/08 11:09 AM
11/12/08 11:09 AM
Posts: 173 Indiana
swepty
Indiana
What would you take for the computer?
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck
1986 Power Ram 400hp 360 6" lift
1970 Plymouth custom suburban 318 4" drop
1996 Dodge 1500 360 4wd 3" lift
North Central Indiana Mopar Club member
[Re: vdriver]
#145574
11/12/08 11:10 AM
11/12/08 11:10 AM
Posts: 173 Indiana
swepty
Indiana
Tried, but I'm not a member...
