92 dodge stealth 3000 gt, cooling fans not working #1455551
06/19/13 11:45 PM
06/19/13 11:45 PM
MNobody Offline OP
MNobody  Offline OP
Working on a buddy's Stealth and i can't get the fans to work. Fuse checks out good. I got the plug off the ECU temp sensor and shorted the two terminals together with the key in the run position and nothing. Any help would be appreciated.
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455552
06/20/13 01:41 AM
06/20/13 01:41 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Haven't worked on a Mitsu for awhile but I recall the (2) water temp sensors are on the bottom part of the radiator. One turns on @ 185 degrees and the other like 205 degrees, just ground each respective lead which triggers a power relay for each fan..
Just my $0.02...
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: Sinitro] #1455553
06/20/13 10:54 AM
06/20/13 10:54 AM
MNobody Offline OP
MNobody  Offline OP
Thanks for the info, this thing is a nightmare. Found more relays and fuses on the drivers fender, fuse was good and if the fans are divided as you say and neither work i'm guessing the ecu must control the fans too? Thanks for the help!
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455554
06/27/13 10:07 AM
06/27/13 10:07 AM
MNobody Offline OP
MNobody  Offline OP
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455555
06/27/13 12:35 PM
06/27/13 12:35 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If u turn on the a/c does the fans run?
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455556
06/27/13 01:40 PM
06/27/13 01:40 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
You're going to need a diagram...hopefully someone can help you out. I've seen some of the early imports with 3 temp sensors...1 for the gauge, 1 for the fans and 1 for the ECU. There's a reason we hated working on that stuff!!
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: AARCONV] #1455557
06/27/13 11:31 PM
06/27/13 11:31 PM
MNobody Offline OP
MNobody  Offline OP
I'll check that tomorrow
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455558
07/15/13 12:24 AM
07/15/13 12:24 AM
MNobody Offline OP
MNobody  Offline OP
Sorry it took so long but the fans did come on with the AC so atleast it's driveable. Thanks for all the help so far.
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: MNobody] #1455559
07/15/13 08:27 PM
07/15/13 08:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used to work on the Dodge Stealth's at our dealer but its been a few years since I did. As was said its best to get the wiring scematic as there was so many different systems even on the Mitubisi cars that I would get the wiring and follow it out. Most fans are controlled by the engine control module and some have more then one speed and more then one relay. I willl say they did not screw up alot but when they did I found out the Japenese like to use alot of relays and switches. With the wiring scematic you can also find which fuses feed them as some are under the hood and some under the dash. I wish I could tell just what it is but they really did not screw up much. Ron
Re: 92 dodge stealth 3000 gt, cooling fans not working [Re: 383man] #1455560
07/21/13 12:57 PM
07/21/13 12:57 PM
MNobody Offline OP
MNobody  Offline OP
Thanks Ron, i'm going to get a manual for it but for as much as he drives it he can run the AC lol.
