trying to fit RB indy head in a-body need help #1455442
06/19/13 06:13 PM
06/19/13 06:13 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I Have a 72 dustpan 440 with ez heads and aindy dual plane the problem is a air cleaner that will fit under the hood ?? anyone??
Re: trying to fit RB indy head in a-body need help [Re: runner12] #1455443
06/19/13 10:43 PM
06/19/13 10:43 PM
AndyF Offline
AndyF  Offline
The Mopar 337 intake might fit under the hood. If not, you'll need to put a hood scoop on the car.
Re: trying to fit RB indy head in a-body need help [Re: AndyF] #1455444
06/19/13 11:56 PM
06/19/13 11:56 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I have a dual snorkel style but with any air cleaner they all seem to hit somewhere
Re: trying to fit RB indy head in a-body need help [Re: runner12] #1455445
06/20/13 01:34 AM
06/20/13 01:34 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
What about spacers under the k frame like the 68 super stock darts? How much clearance is needed? Would that work, I have to imagine that someone has done it!
Re: trying to fit RB indy head in a-body need help [Re: runner12] #1455446
06/20/13 06:37 AM
06/20/13 06:37 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is the hood cut out under the scoop ? how much drop on the base of your aircleaner ?
Re: trying to fit RB indy head in a-body need help [Re: runner12] #1455447
06/20/13 01:29 PM
06/20/13 01:29 PM
AndyF Offline
AndyF  Offline
The Mopar 337 intake is the lowest profile MW intake. If the EZ heads are std port size then go with something like a Street Dominator.
You're trying to fit 10 lbs of spuds into a 5 lb bag so doen't be surprised when it all doesn't fit!
Re: trying to fit RB indy head in a-body need help [Re: AndyF] #1455448
06/20/13 05:31 PM
06/20/13 05:31 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I know Im trying to help a buddy , yes it is cut out the same size hole as the scoop .I think we will have to go custom. THANKS
