426 c.i. engine was rebuilt a couple of years ago and only has about 250 miles on it - prior owner sold it to me with
"BRAD PENN® PENN-GRADE 1® BREAK-IN OIL, an SAE 30 mono-grade oil formulated specifically to meet the critical lubrication needs of new engines during break-in while allowing proper seating of rings and component ‘run-in’."
Questions:
1. how long do you have to use break in oil until the engine is broken in?
2. should you change it to a new fill of break in oil during that period?
3. do the extra break in additives harm the engine if you use it longer than you need to?
thanks!
