70 Bendix power disk booster
#1455290
06/19/13 12:02 PM
06/19/13 12:02 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
It seems I may have a problem with my brake booster. Wondering the best way to go about fixing/replacing it. Anybody know where to buy a rebuilt unit? Looks like this: Thanks, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 70 Bendix power disk booster
[Re: hemi71x]
#1455293
06/19/13 12:36 PM
06/19/13 12:36 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Booster Dowey
That would be Booster Dewey and yes he's the one to use.
[Re: gtx6970]
#1455298
06/19/13 05:06 PM
06/19/13 05:06 PM
DPelletier
Thanks all; Bill, I'd probably do the rebuild thing but althought the price sounds good, shipping to and from the US with the associated delays dampens my enthusiasm for that particular solution. PLUS, I'm not 100% sure I have the correct booster in the first place! I see that MBM Brakes (where Pirate Jack gets his from) shows two different boosters that appear identical in the pictures on the site; - PB8536-1 which says it's for a '66 - '69 B body - PB8536-2 which says it's for a '70 - '74 B and E body. http://mbmbrakeboosters.com/ Anyone know what the differences between the two OEM parts are? If I knew that, I could eliminate having the wrong booster as part of my issue... Dave
1974 'Cuda
[Re: DPelletier]
#1455299
06/19/13 05:09 PM
06/19/13 05:09 PM
DPelletier
...and now that I'm poking around on their site, I notice that they appear to show the wrong "power brake reinforcement plate" for 1970 as well so I'm not sure how correct their stuff is likely to be...
1974 'Cuda
[Re: DPelletier]
#1455301
06/19/13 05:36 PM
06/19/13 05:36 PM
DPelletier
OK, I called Pirate Jack (MBM won't accept my queries as I'm not a dealer). I explained that the catalog data is incorrect as it relates to the power brake firewall re-inforcement plate and that my '70 b-body uses the one that they show as correct for a '66 - '69. He confirmed there was an error in the catalog and said the booster for the '66 - '69 is correct for my '70 (which makes sense that the application should be '66 - '70 b body vs. '71-'74 B and E which share the same firewall). Basically he said I would know if I had the wrong booster because the E body (and I presume '71 and up B body) has a different spacing on the firewall mounting bolts. Can anyone confirm this? ...he didn't know if the "Pedal bracket swivel" (bellcrank) was the same or not between the two applications. Dave
1974 'Cuda
[Re: DoctorDiff]
#1455305
06/20/13 12:39 PM
06/20/13 12:39 PM
DPelletier
I also handle the MBM repro Bendix boosters.
The '70 and earlier B-body unit will interchange with OEM under-dash linkage, but you must enlarge the hole in the stock firewall stiffening plate.
The E-body/'71-up B-body version was never available from the factory. It has a different bolt pattern on the back and a longer input rod. It won't interchange with OEM under-dash linkage, so you must buy the MBM linkage.
I'm also working on B and E body "Hemi" (under-hood) linkage for this booster.
Good to know that you carry the stuff (MBM's website only lists Pirate Jack). If I need one, I'll definitely get it from you.
OK, so what Pirate Jack's told me was that they would need to sell me the Booster Conversion Kit BCK8536-1 (for '66 - '69 cars)and then delete the master cylinder (which is just as well because it appears to be a Hemi style cylinder with the line connections on the fender side). The guy didn't know if the bellcrank linkage was the same or different between the -1 and -2 kits.
....going back to my notes when I put the car together a few years ago, Mike G. (Dayclona) gave me a bunch of measurements and one of his comments was "...IIRC the 68/69 (linkage) is the same, and the 70 is slightly different in pivot locations/angles/geometry, hence the different bellcranks..."
I ended up having to space the booster away from the firewall plate to get enough clearance to hook up the linkage to the pedal without having the brakes partially depressed while the pedal is in the fully up position so I strongly suspect that something is wrong. The pedal assy is PROBABLY original, but who knows for sure.
...my god what a PITA! I've probably taken the linkage on and off a dozen times now!
Sooo; is the hole size difference the reason these kits come with a new firewall plate?
not sure exactly what you mean when you say the E body and '71 and up B body "was never available from the factory"
I suppose the safest thing to do to make sure everything works is to buy the entire BCK8536-1 kit c/w firewall plate, linkage kit, booster and master cylinder....I wonder if the correct master is available?
1974 'Cuda
