Page 1 of 3 1 2 3
2000 300m 3.5L won't stay running #145505
11/04/08 02:31 PM
11/04/08 02:31 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
My wifes car is dead in a parking lot. All was well when she stopped at lunch time. Now the car turns over fine, fires then immediately dies.
Of course she had a scanner with her thats not throwing any codes.
A couple weeks ago I replaced the cam pos sensor because 3 days in a row the car engine would just die on her morning commute. Once I swapped the sensor it was fine until now.
I'm thinking the Crank pos sensor might be faulty??
The fact that it fires up but wont stay running is puzzling.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145506
11/04/08 02:46 PM
11/04/08 02:46 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Should be throwing a P0016
Hmm....
Positive on fuel delivery?
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2000 300m 3.5L won't stay running [Re: 70Coronet500Vert] #145507
11/04/08 03:09 PM
11/04/08 03:09 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
No codes unless my Actron reader is not picking them up. Back when I had troubles before it didn't throw any codes even when the car wouldn't fire.
I would assume if the fuel pump was bad, repeated attempts to start would eventually result in no fire at all when rail pressure was nil.
The cam sensor was a B/W part from Advance Auto.
Whats the point of 2 sensors? The cams don't change phasing in relation to the crank at all do they??
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145508
11/04/08 03:28 PM
11/04/08 03:28 PM
St Charles MO
St Charles MO
I believe if there is a variance detected, your car gets shut off in order to preserve the engine to th fullest extent possible. These are interference engines and a misalignment between these wil result in valves meeting pistons.
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2000 300m 3.5L won't stay running [Re: 70Coronet500Vert] #145509
11/04/08 04:02 PM
11/04/08 04:02 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I had a similar issue with my 3.2 intrepid.
It was the crank sensor. A mechanic buddy told me the late model crank sensor is chrysler's new ballast resistor.
Re: 2000 300m 3.5L won't stay running [Re: The Shadow] #145510
11/04/08 05:59 PM
11/04/08 05:59 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Got to the car this evening and it fired right up. I'm going to swap the sensors snd hope it doesn't happen again.
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145511
11/05/08 02:34 AM
11/05/08 02:34 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Crank and cam sensors:
Cam is for TDC fire on #1.
Crank is for ignition timing.
Re: 2000 300m 3.5L won't stay running [Re: Jim_Lusk] #145512
11/05/08 02:35 AM
11/05/08 02:35 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Also, in my experience (my cars only). A fire/die (won't idle) has tended to be an idle speed motor/throttle body needing cleaned. A dirty throttle body won't set a code.
Re: 2000 300m 3.5L won't stay running [Re: Jim_Lusk] #145513
11/05/08 10:22 AM
11/05/08 10:22 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I swapped the crank sensor for insurance. The one I took out looked identical to the one I replaced.
We'll see what happens.
I would guess that a crapped up IAC pintle or TB would slowly deteriorate performance wise right? Do the IAC motors react to cleaning or do they need to be replaced??
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145514
11/05/08 06:19 PM
11/05/08 06:19 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Today my wife got stuck again. Same issue but its throwing code P1391 which is intermitant loss of cam or crank position.
AAA is bringing it home soon and I guess I am going to go on a witch hunt for bad wiring or connectors.
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145515
11/05/08 08:30 PM
11/05/08 08:30 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Of course when the AAA guy gets there, it starts right up with no issue.
So I let it idle in the driveway for a while and it eventually dies out.
So I scan for codes and now it showing 725?? But then I decide to check the codes using the car by cycling the ignition 3 times fast, I get a whole different set of codes....
I'm getting P0320 which is no crank ref signal at PCM. P1389 which has to do with the auto shutdown relay (the engine stopped but key was not turned off) and last but not least the same P1391 which is the intermittant cam/crank pos signal.
I pulled the sensor and checked the connector. Fooled with it and reinstalled and it started back up. Again, when I let it idle it died again. Same codes.
I guess something is breaking the connection when the car warms up and reconnects when it cools down..........
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145516
11/06/08 08:01 AM
11/06/08 08:01 AM
St Charles MO
St Charles MO
Sounds like both cam and a crank sensor replace.
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 2000 300m 3.5L won't stay running [Re: 70Coronet500Vert] #145517
11/06/08 09:23 AM
11/06/08 09:23 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
Belt starting to breakdown?
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: 2000 300m 3.5L won't stay running [Re: moepwr] #145518
11/06/08 10:33 AM
11/06/08 10:33 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I just put a new timing belt on it. The cam sensor was replaced about a month ago. Crank sensor 2 days ago.
I am also getting p1389 wich is an auto shutdown relay fault after the car dies. I was assuming it was because the engine stopped running while the key was on. But somebody elsewhere suggested that the relay may be failing when warm and killing the motor also causing the intermittant signal and loss of crank signal.
It definatley sounds plausable.
Another thing I noted is that my universal Actron scan tool doesn't pick up all the codes compared to cycling the ignition 3 times fast......
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145519
11/06/08 11:56 AM
11/06/08 11:56 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Actron = junk, but you probably already knew that.
Check all the grounds......
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145520
11/06/08 11:58 AM
11/06/08 11:58 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just a thought, But make sure the replacement sensers are correct for a NGC controller equipped car. They are different from SBEC cars
Re: 2000 300m 3.5L won't stay running [Re: gtx6970] #145521
11/06/08 12:01 PM
11/06/08 12:01 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Huh??
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145522
11/06/08 03:55 PM
11/06/08 03:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
NGC = Next Generation Controllers ( these have 4 plug connectors )
SBEC = Single board engine controllers ( this has 3 plug connectors )
Each ECM requires there own sensors. And just because the sensors are new doesn't mean the right for the car
Re: 2000 300m 3.5L won't stay running [Re: gtx6970] #145523
11/06/08 04:24 PM
11/06/08 04:24 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Ah, I understand. I noticed a distinct difference in PCM design when surfing for PCM's on ebay. One has 2 grey plugs on the end the other 4 black plugs on the large flat side. It appears to be a change somewhere within 2002.
Mine is this one.
I guess the later one is this one.
I am guessing if I got the wrong sensor it wouldn't work at all right?? I would be suprised if the connectors were the same.
Re: 2000 300m 3.5L won't stay running [Re: CJK440] #145524
11/06/08 04:47 PM
11/06/08 04:47 PM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
Did you use Mopar parts? Most of the aftermarket sensors I've seen don't work very well.
Page 1 of 3 1 2 3
