throttle cable #1454808
06/18/13 12:58 PM
06/18/13 12:58 PM
indy
70moparmike Offline OP
indy
will a stock throttle cable length be right for a performer rpm intake on a 69 b body? or do i need to get a longer cable, thanks for any help with this. also have the ar bracket to raise it.
Re: throttle cable [Re: 70moparmike] #1454809
06/18/13 02:43 PM
06/18/13 02:43 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: throttle cable [Re: VernMotor] #1454810
06/18/13 03:53 PM
06/18/13 03:53 PM
indy
indy
are you saying the stock cable will work? thats what i need to know?
Re: throttle cable [Re: 70moparmike] #1454811
06/18/13 04:12 PM
06/18/13 04:12 PM
AndyF Offline
AndyF  Offline
The stock cable might be long enough. If not, there should be longer cables available. The /6 cable used to be the one to buy but it might not be available anymore.
Re: throttle cable [Re: AndyF] #1454812
06/18/13 05:19 PM
06/18/13 05:19 PM
Check the one you have first, I think all the stock V8 four barrel cars, regardless of body style or V8 motor size, I had or work on that we put a BB RPM intake on worked fine The OEM two barrel cables did not reach or work well on any four barrel intake and carb swap we did
Re: throttle cable [Re: Cab_Burge] #1454813
06/18/13 07:15 PM
06/18/13 07:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That is the long cable 6cy..that what you need. I never had a stock cable that work well with a 4 barrel carb..
Re: throttle cable [Re: VernMotor] #1454814
06/18/13 09:52 PM
06/18/13 09:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Also the Lokar cable will work good with it. I use the Lokar cable on my 63 using the Indy dual plane which is about as high as the RPM intake. Ron
Re: throttle cable [Re: 383man] #1454815
06/18/13 10:35 PM
06/18/13 10:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went with the Lokar also,nice easy and looks good too
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
