1967 Barracuda trunk lock cylinder key needed.
#1454795
06/18/13 12:05 PM
06/18/13 12:05 PM
Posts: 69 Decorah, IA
fratzog
Decorah, IA
I am trying to get a trunk lock cylinder decoded for a key. It is from a 1967 Barracuda. The is a "CB 486" stamped on the outer case of the cylinder. Is this the key code? If so, can someone let me know the punch sequence, or cut a key from the code and mail it to me? Thank you!!
Re: 1967 Barracuda trunck lock cylinder key needed.
[Re: fratzog]
#1454796
06/18/13 12:26 PM
06/18/13 12:26 PM
RapidRobert
I just dealt with this & I took it to a locksmith & they drilled a small hole in the side so the innards would come out then they made a key for it. Several day turnaround & was inexpensive
[Re: RapidRobert]
#1454797
06/18/13 01:50 PM
06/18/13 01:50 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
RR your lock smith must not be too good.I took my 57 to a local guy we dealt with at the shop.He pulled it,cleaned and lubed and cut my key all under an hour.He made me 3 trunk keys and 2 spare Ign keys.Total was under 25 bucks.Just pull it and any good lock smith can make a key.Rocky
Chrysler Firepower
[Re: Jim_Lusk]
#1454799
06/18/13 02:09 PM
06/18/13 02:09 PM
therocks
Niles , Ohio
Jim I think it took my guy like 5 minutes to pull the one from the 57.He had the hardest part matching a key to it as they changed them in the early 60s.I still need to get spare Ign keys made for my 65.Rocky
Chrysler Firepower
