Re: Nug luts
[Re: ahy]
#1454674
06/18/13 01:18 AM
06/18/13 01:18 AM
RapidRobert
I'm not visualizing what it'd take but if you could support the back side of the flange solid you could knock em out with a BFH to eliminate the risk of damaging the bearing or bending the flange. You might just try easy tapping on the 2 damaged ones as some are in there fairly loose, you might get lucky. Just discipline yourself not to bang harder if they ain't loose
Re: Nug luts
[Re: MoparMarq]
#1454676
06/18/13 09:24 AM
06/18/13 09:24 AM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Great minds think alike..... And apparently so do all of us. I knocked out the offending two last night, stacked some washers and grabbed my impact. It wouldn't pull them all the way in. Tried a bit of heat on the axle flange and tried again. Still no luck.
Guess ill be pulling the axles and using a press.
Just for grins let me tell ya what started this....
73 Dart Sport blew a head gasket. So, i pulled the heads and I had the heads gone through at a shop. New guides, resurfaced, new seals. Good to go. I couldn't see myself putting those nice clean heads and intake on that greasy engine. I pulled the engine and transmission out, cleaned it all up, put new seals and gaskets in the engine and trans. Repainted it, repolished the alum valve covers, replaced the nasty water pump and alternator and repainted all accessory brackets. Of course new motor mounts too. Well, if you go that far, might as well rebuild the carb and toss on new cap, rotor, plugs and wires too.
But, now there was no way I could put that pretty engine In That filthy engine bay. I spent the better part of a day power washing, scrubbing and degreasing the engine bay. Well, while I was at it, I figured I'd just crawl under it and clean the entire underside of the car. That was fun.
As I looked at the pretty engine and clean engine bay, I figured might as well replace all the front suspension/steering parts while they are easy to get to. So, all new bushings, bearings, seals, tie rod ends, pitman arm, idler arm, and brakes went on.
The steel brake lines just looked put of place though.... Quick call to fine lines got me a new set of steel lines for the front of the car. I put them on and FINALLY put the engine and trans back in. But dang, those trans cooler lines were looking rough. So, of course I made some new ones quick.
This process has taken about 2 weeks so far, of course i have a "day job" so things take awhile. I started it up Friday evening again, sounds great, so far no leaks.
Before I start driving it again, I needed to fix those two stripped lugs. Welllllll, since the brake system is empty still and I'm already taking things apart, new shoes and wheel cylinders are in order along with the new lugs. So now, I'll be pulling the brakes apart, pulling the axles replacing all 10 lugs, cleaning everything and replacing the rear brakes.
But wait.... There's more! Since tomorrow night ill be pulling the axles anyway, I might as well put new bearings and seals in the rear axle too. Guess those U joints could use replacing while I'm at it. If only I had a big bolt pattern A-body 8 3/4" rear I'd just remove the 8 1/4" and put a 3:55 sure grip in.
Anything I missed? Lol
The bad thing about all of this is, I'm supposed to be starting the body work on my 70 Challenger. It's engine has been done for 6 months!
Laine
Re: Nug luts
[Re: Lmopar69]
#1454677
06/18/13 10:04 AM
06/18/13 10:04 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Look at the washers you are using as they may be why the lug won't pull the rest of the way thru because the washer hole is smaller than the shank of the lugnut. I have banged out many lugs over the years and used a lugnut backwards to pull the lugs back in. If I have an axle out then I'll press them in but if it's in the car I have never had an issue getting them in.
Re: Nug luts
[Re: Lmopar69]
#1454679
06/18/13 10:17 AM
06/18/13 10:17 AM
JohnRR
U.S.S.A.
Maybe it's my "fisher price" impact..... Time to bust out the breaker bar and try again.
I have done it with a 4 way. the shank on the lug , the part in the axle , is larger than 1/2" , something like .650 , if you are using 1/2" washers the hole is too small. Look at the washer closest to the axle flange it will tell you if the shank is hitting it.
Put the drum on then stack up a couple washers and retry ...
Make sure you are greasing the threads and I wouldn't do it with an impact as you may be overstressing the studs trying to pull the stud farther than your setup will allow.
Re: Nug luts
[Re: Lmopar69]
#1454680
06/18/13 12:48 PM
06/18/13 12:48 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I think we've all been there. My Supra has a blown head gasket. So a later model inline 6 is getting swapped in. Since the engine is coming out, might as well swap in the trans with the higher 5th gear ratio. Since it's out, might as well put in a new clutch. Since it's up on jack stands, might as well replace the control arm bushings...
Good luck finding an endpoint.
Re: Nug luts
[Re: JohnRR]
#1454681
06/18/13 12:50 PM
06/18/13 12:50 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
I've had some parts store lugs strip off the threads pulling them in with the washers. ARP studs always zip right in for me using the same technique. The cheap ones seem to be a really soft metal, while the ARP studs are some good quality.
I want my fair share
Re: Nug luts
[Re: Polarapete]
#1454683
06/18/13 03:27 PM
06/18/13 03:27 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I use a larger nut instead of washers. One the end of the lug nut will fit into, but not go all the way through. We've done them this way for 20 plus years. Although if you use cheap studs, then sometimes will spin and strip. You need a good impact wrench though, otherwise they won't pull all the way through.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Nug luts
[Re: a12superbee]
#1454685
06/19/13 06:43 AM
06/19/13 06:43 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Aren't there two different sized lugs with the knurled part being the difference, like .120 ish?
Yea, need to be careful on what knurl you get. Plus if the new ones are a tad bigger, the impact/breaker bar may not work leaving you with a small gap on the backside, if the wheel stud does not get pulled all the way in, it could slowly pull in over time and as that happens, you may lose torque on the lug nut
**Photobucket sucks**
Re: Nug luts
[Re: 5thAve]
#1454687
06/23/13 12:05 PM
06/23/13 12:05 PM
Lmopar69
Doniphan, Nebraska
Yes nug luts, or lug nuts for the grammar police. I got all the new lugs put in yesterday. Pulled them in with an old nut. Same way I tried before, but this time it worked slicker than greased owl sh@$.Now to drop the fuel tank, clean it up and then it's back on the road with this thing. Laine
