98 diesel ever had this problem? Help me guys. #1454577
06/17/13 09:21 PM
06/17/13 09:21 PM
Newberry Springs, CA
69Mannix Offline OP
69Mannix  Offline OP
Help me guys, Am having a problem when about 1400 rpm's to 2100 rpm's Seems the engine jumps about 150-200 rpm. Seems like it is trying to shift into like passing gear. It will do it one time after another. Not like the trans slips, just like it is trying to jump to a lower gear.
Re: 98 diesel ever had this problem? Help me guys. [Re: 69Mannix] #1454578
06/18/13 03:23 PM
06/18/13 03:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
for Rinodart...I think he had this problem recently?
Re: 98 diesel ever had this problem? Help me guys. [Re: 69Mannix] #1454579
06/18/13 09:13 PM
06/18/13 09:13 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mine was the TPS having dirty connections. It would go up a couple hundred RPM then go back quickly. Then I lost the overdrive altogether and asked questions here which lead me to disconnect the wires to the TPS and making sure they were clean. After cleaning them up and connecting/disconnection them a couple times I have had no problems.
JB Rhinehart, Realist
A-Body's RULE!
Re: 98 diesel ever had this problem? Help me guys. [Re: 69Mannix] #1454580
06/19/13 09:10 AM
06/19/13 09:10 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
The 98.5-02 24V automatics had a lot of electrical gremlins from the start. As evidenced by RhinoDart's reply and mine, there can be more than one reason for a hunting tranny. My problem was the torque convertor locking and unlocking in overdrive. Mine would jump about 50-75 RPM, so I did the cheapest trick possible - wrap the wire from the battery to the alternator in a few layers of heavy foil, then wind electrical tape around the whole thing to completely cover the foil and seal up the ends. That was shortly after I bought it in 2007, nearly six years ago. It's never happened again.
The problem stems from an erratic voltage signal sensed by the lockup solenoid. When that happens, it opens and closes repeatedly. The battery wire "leaks" voltage, that's why wrapping it helps. Seriously, try it. It's nearly free, and free is good.
BTW, 2100 RPM is about 300 higher than the sweet spot. Your fuel consumption will greatly increase above 1800.
OIF V and OEF X veteran and proud of it!
Re: 98 diesel ever had this problem? Help me guys. [Re: 69HemiGTX] #1454581
06/19/13 09:17 PM
06/19/13 09:17 PM
69Mannix Offline OP
69Mannix  Offline OP
I will try both of these fixes, and yes mine is a 98.5 24v. I hope this helps as have to make a 600mile drive and do not want problems! Thanks will let you know!
Re: 98 diesel ever had this problem? Help me guys. [Re: 69Mannix] #1454582
06/21/13 01:16 AM
06/21/13 01:16 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My friends 98.5 had a similar problem... it's been a few years since I drove it, so can't remember exactly. But he ended up having the transmission rebuilt and the sensor(s) replace on the trans and still did it. His ended up being the computer. Pretty hard to find a good one, so he sent it out to get rebuilt and its been fine since.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
