Could you get a red stripe on F5 green 69 bee #1454524
06/17/13 07:02 PM
06/17/13 07:02 PM
ME
79machocharger Offline OP
ME
I've seen red stripes on a F8 green bee but could you get one on F5 green. Any one have a sheet on what colors you could get a red strip on 69 bees. I want to make my 69 1/2 clone alittle different but only want to do it if it was possible. I'm thinking it would look killer with the red line tires and the red on the hood and make it really stand out from the rest.
Re: Could you get a red stripe on F5 green 69 bee [Re: 79machocharger] #1454525
06/17/13 07:05 PM
06/17/13 07:05 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
Yes!if it looks good on F8 it will look good on F5!
Re: Could you get a red stripe on F5 green 69 bee [Re: 1970A13] #1454526
06/17/13 08:59 PM
06/17/13 08:59 PM
ME
ME
Here's a picture of what looks to be an f8 bee with red stripe. Any one have a better picture of a green bee with red stripe. I want to make I like the looks of it first.
Re: Could you get a red stripe on F5 green 69 bee [Re: 79machocharger] #1454527
06/19/13 11:20 PM
06/19/13 11:20 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For some reason I can't understand, F8 looks way darker than F5 in the color charts. And there has been discussion that grille blackout paint was omitted for F8, presumably because it's so dasrk.
My one-owner car is F5 with F8 on the upper door frames. Here's a photo in sunlight showing both colors on the door. This paint never saw the light of day until I took off the vinyl/cardboard door panel recently, so the paints have to be close to the factory fresh colors.
Re: Could you get a red stripe on F5 green 69 bee [Re: kentj340] #1454528
06/20/13 12:16 PM
06/20/13 12:16 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
My one-owner car is F5 with F8 on the upper door frames. Here's a photo in sunlight showing both colors on the door. This paint never saw the light of day until I took off the vinyl/cardboard door panel reently, so the paints have to be close to the factory fresh colors.
1) the F5 under the door panel never may have seen the light of day, but the F8 did.
2) I don't believe the part under the panel that you've labelled F8 is F8; it is F5 discolored by the adhesive, the only F8 part is the exposed upper door frame.
3) interior paint is different than the exterior paint and fades much faster in my experience. I know that it's different because I screwed up and used the PPG formula for the exterior on my interior only to find the correct interior formula at a later date.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Could you get a red stripe on F5 green 69 bee [Re: kentj340] #1454529
06/20/13 12:18 PM
06/20/13 12:18 PM
DPelletier Offline
DPelletier  Offline
...and for WIW, I believe most F8 cars got the blackout despite the assembly line memo.
Re: Could you get a red stripe on F5 green 69 bee [Re: DPelletier] #1454530
06/21/13 12:09 AM
06/21/13 12:09 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Not so. If you saw the door in person, it would be obvious to you that the factory masked off the F5 and painted the F8. The factory masking is why there is a sharp, straight edge between the colors. The adhesive is only where you see it, with no adhesive at the masking lines. That's the reason I took the picture and labeled it for myself. Same is true elsewhere on the door. And also this same shade of F8 is on the rear seat window frame and the roof rail - they all match.
I might add that the photo is the bottom of the door, not the "upper door frame". I had never noticed that they painted the bottom part with F8 also. This is a 69 Barracuda - don't know if other models have the bottoms of the doors painted same as the upper door frame.
Seems reasonable that the interior paint was not of exterior quality, as you say, because the interior F8 is definitely not very dark and not so different from the F5 today.
The exterior of my car is F5, but several exterior F8 cars I have seen look so close to F5 that I had to look at the fender tags to be sure.
Re: Could you get a red stripe on F5 green 69 bee [Re: kentj340] #1454531
06/21/13 12:23 AM
06/21/13 12:23 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
FWIW - this is an awesome thread. Both with seeing a green bee with a red stripe and then seeing the paint differences that KentJ is pointing out. Thanks!
Re: Could you get a red stripe on F5 green 69 bee [Re: WyleECoyote] #1454532
06/21/13 12:37 AM
06/21/13 12:37 AM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
My F5 GTX. A friend of mine has an F8 Road Runner and is almost twice as dark as the F5. Not even close.
Re: Could you get a red stripe on F5 green 69 bee [Re: moparcanuk] #1454533
06/21/13 08:13 AM
06/21/13 08:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Why not? As I understand it you checked the block for stripe, if you wanted red you checked RED.
Coming soon!!!!
