Adjuster size on w2 ductile iron rockers #1454504
06/17/13 05:16 PM
06/17/13 05:16 PM
western PA
Sb Valiant Offline OP
western PA
I am wondering what the adjuster size is on a set of w2 econo ductile iron rockers. I don't know if the make is MP or they are crane. The adjusters are worn out and I was thinking if they are the same size as the ones I have on other rockers maybe I could use them???
Re: Adjuster size on w2 ductile iron rockers [Re: Sb Valiant] #1454505
06/17/13 06:06 PM
06/17/13 06:06 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Same as the crane aluminum, 3/8-24 I think.
Re: Adjuster size on w2 ductile iron rockers [Re: Hot 340] #1454506
06/17/13 06:36 PM
06/17/13 06:36 PM
western PA
western PA
Thanks for the reply. Can anyone else varify this?
Re: Adjuster size on w2 ductile iron rockers [Re: Sb Valiant] #1454507
06/17/13 07:09 PM
06/17/13 07:09 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
you can. Count how many threads are in one inch of the adjuster. Or how many are in 1/2 inch and multiply by two. Diameter is def 3/8.
Re: Adjuster size on w2 ductile iron rockers [Re: Hot 340] #1454508
06/17/13 07:33 PM
06/17/13 07:33 PM
western PA
western PA
All ok thanks
