tach issue #145450
11/04/08 09:47 AM
11/04/08 09:47 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
where on the firewall harness would the tach wire be located?
Re: tach issue [Re: kingkt] #145451
11/04/08 09:57 AM
11/04/08 09:57 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Depends on which car and year.
1979 Chrysler 300 1968 Barracuda project
Re: tach issue [Re: LS-300] #145452
11/04/08 10:05 AM
11/04/08 10:05 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
its a 70 challenger r/t
Re: tach issue [Re: kingkt] #145453
11/04/08 01:53 PM
11/04/08 01:53 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Info I have states that the tach wire is seperate. It should be an 18ga gray wire with a tracer that goes thru a grommet in the firewall. This would be true for all engines except the Hemi.
Re: tach issue [Re: LS-300] #145454
11/04/08 02:03 PM
11/04/08 02:03 PM
that how I thought it was too
Re: tach issue #145455
11/04/08 10:06 PM
11/04/08 10:06 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Looking at some old engineering drawings that I have. If the tach did go to the connector it would be in pin #20.
Re: tach issue [Re: LS-300] #145456
11/05/08 11:02 PM
11/05/08 11:02 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thanx for the info, ill look into your suggestions. in the meantime, anyone know why the tach needle would go straight to the top when the key is on and after it starts?, ive removed the wires to the coil and the alt, and it does the same thing. thanx
Re: tach issue [Re: kingkt] #145457
11/05/08 11:10 PM
11/05/08 11:10 PM
sounds like you have the tach hooked up to 12v. better check it with a meter
Re: tach issue #145458
11/06/08 12:55 AM
11/06/08 12:55 AM
you might jump the tach wire directly to the coil neg, start the eng & see if the tach itself is good.
Re: tach issue [Re: RapidRobert] #145459
11/06/08 01:55 AM
11/06/08 01:55 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
ill definetely try that, thanx.
i notice that there is a pos and a neg wires connected to the alt gauge, and thats what seems to power up the complete dash cluster. anyone know if this is correct? appreciate all your help guys! this one has got me stumped
Re: tach issue [Re: kingkt] #145460
11/06/08 09:33 AM
11/06/08 09:33 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Yes, in a rallye dash like on my A body, the
wires go directly to the amp gauge and basically power out from there.
