'03 Ram Turn Signal Issues #1454472
06/17/13 03:18 PM
06/17/13 03:18 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
What would cause the switch to work opposite at times (ex. turning left blinker works on left) not all the time just here and there. Bad switch? Thanks for any advice!
Re: '03 Ram Turn Signal Issues [Re: indytex96] #1454473
06/17/13 09:18 PM
06/17/13 09:18 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I have seen this issue several times. It is usually the multi-function switch that is the problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '03 Ram Turn Signal Issues [Re: indytex96] #1454474
06/17/13 09:22 PM
06/17/13 09:22 PM
Mass. USA#1
hemi70 Offline
hemi70  Offline
Mass. USA#1
Likely a faulty multifunction switch. Switch sends multiplexed signal to cluster, cluster sends bus message to FCM, FCM operates approiate lights.
Switch probably sending wrong voltage to cluster.
Gary.
Re: '03 Ram Turn Signal Issues [Re: hemi70] #1454475
06/17/13 11:20 PM
06/17/13 11:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
For years I have not had a right trailer turn signal/brake light so I was told it was the FCM. I replaced the FCM a couple months ago and still have the issue, could it also be the multifunction switch and where the heck is it located?
JB Rhinehart, Realist
A-Body's RULE!
Re: '03 Ram Turn Signal Issues [Re: Rhinodart] #1454476
06/18/13 12:18 AM
06/18/13 12:18 AM
Mass. USA#1
hemi70 Offline
hemi70  Offline
Mass. USA#1
If it is only the trailer portion that is inop then it wont be multi-switch (turn signal stalk).
Factory trailer tow harness? relay in IPM/FCM clicks?
Need to review wiring diagram and check circuits with test light front to back.
Gary
Re: '03 Ram Turn Signal Issues [Re: hemi70] #1454477
06/18/13 01:34 PM
06/18/13 01:34 PM
SE Kansas
I
I
SE Kansas
Is the switch that hard to change replace or need special tools? Wondering if Ishould let the dealer fix...
Re: '03 Ram Turn Signal Issues [Re: indytex96] #1454478
06/18/13 08:50 PM
06/18/13 08:50 PM
Missouri U.S.A.
Missouri U.S.A.
It is easy to replace. Just remove the upper and lower plastic steering column covers behind the steering wheel. The screws come in from the bottom of the lower cover. After you get that off just remove the 2 screws holding it to the column and electrical connector. Then grab the handle and pull it straight out of the bracket. FWIW, a Mopar switch will come with the bracket on the switch. Just remove the switch from the bracket and install. Otherwise the steering wheel will have to come off to replace the bracket, resulting in much more unnecessary work. One more thing, Dodge put an extended warranty on the switches for the 06 Rams. This switch will also fit your truck. It can be had for somewhere around half the price as the one they will try to sell you at the dealer for your truck. Just ask for part number CNH3X2DDAA.
10.02@134
