BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? #1454187
06/17/13 02:23 AM
06/17/13 02:23 AM
Uranus
strokerchall Offline OP
Uranus
Just curious if there's anything I should do for precautionary reasons after I install my 512 stroker to keep it from twisting/wrecking anything?I don't plan on running the quarter mile with slicks but may put a street slick on just to help hook-up.
There is frame connectors welded in already.
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: strokerchall] #1454188
06/17/13 02:38 AM
06/17/13 02:38 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Anything to stiffin it is good, after frame connectors is torque boxes, front and back and weld up the k-frame (welds stink on those). Frame connectors really helped my vert.
-Daty
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: Daty Rogers] #1454189
06/17/13 12:02 PM
06/17/13 12:02 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
frame connectors are a good idea
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: terzmo] #1454190
06/17/13 01:38 PM
06/17/13 01:38 PM
dogdays Offline
dogdays  Offline
It'd be a really good idea to go over the welds on your K-frame and check for cracks at the same time. Recent posts have reinforced the idea that K-frame manufacture wasn't high quality.
Torque boxes would be your next step.
I still remember the body twisting I saw on Challengers and Barracudas that were running 440s at the drags. The question is a wise one.
R.
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: dogdays] #1454191
06/19/13 10:34 PM
06/19/13 10:34 PM
Uranus
Uranus
to weld in torque boxes means stripping the carpet and burning off paint in/out?
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: strokerchall] #1454192
06/20/13 12:49 AM
06/20/13 12:49 AM
What year and body style are you working on and does it have a roll bar or cage in the car now?
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: strokerchall] #1454193
06/20/13 12:21 PM
06/20/13 12:21 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
If they are decent frame connectors, installed properly and you don't plan on running the car at the track, then you are probably fine. ....'course more can't hurt.
Remember that it's traction that is the issue, not power.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: Cab_Burge] #1454194
06/20/13 07:09 PM
06/20/13 07:09 PM
Uranus
Uranus
its a stock street driven 70 challenger,no cage etc
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: strokerchall] #1454195
06/20/13 10:54 PM
06/20/13 10:54 PM
IN
ahy Offline
ahy  Offline
IN
One of the first things I did to my 318 Challenger was to beef the chassis. Frame connectors helped it ride and drive better dead stock. A noticeable improvement. Now it has a 496, 5 speed, stiff suspension ect. and I'm really glad I have the connectors.
Launching with slicks and 512 can tear body panels. With street tires probably not... but the connectors will make it a better ride even when you are not hammering it.
Re: BODY/FRAME REINFORCEMENT AT WHAT HP/TQ? [Re: strokerchall] #1454196
06/21/13 12:14 AM
06/21/13 12:14 AM
Is it a R/T Challenger or a non R/T chassis? The reason I'm asking is the R/T have the reinforced torque boxes in front of the front leaf spring mount and the rear sub frames and the rocker panels If your car doesn't have them adding them will help stiffen the back of the car up some They will help your subframe connectors stiffen the back of the car also
