Page 2 of 3 1 2 3
Re: Fuel flow thru reg? [Re: Thumperdart] #1453777
06/16/13 11:13 PM
06/16/13 11:13 PM
nc
E
emarine01 Offline OP
E
nc
We just ran all new 1/2 inch line from the pump to the reg, fuel tank on top of pump with a straight drop about 10 to 12 inches to the pump feed which is 1/2 also. Removed all filters for the tests, Pump seems a bit louder than normal?
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453778
06/16/13 11:16 PM
06/16/13 11:16 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
no its not, sounds like you need a new pump
this^^^
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Fuel flow thru reg? [Re: emarine01] #1453779
06/16/13 11:23 PM
06/16/13 11:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My pump made some horrible noises right before it locked up and burned down.......Which pump do you run?
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453780
06/16/13 11:28 PM
06/16/13 11:28 PM
nc
E
E
nc
Any recommendations on pumps for around 650Hp give or take a few, how big of a pump do I really need?
Re: Fuel flow thru reg? [Re: Thumperdart] #1453781
06/16/13 11:30 PM
06/16/13 11:30 PM
nc
E
E
nc
BG 280
Re: Fuel flow thru reg? [Re: emarine01] #1453782
06/16/13 11:32 PM
06/16/13 11:32 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Just buy the magnafuel 500, for the money difference its a no brainer. Your probably going to want to go faster at some point anyway.
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453783
06/16/13 11:49 PM
06/16/13 11:49 PM
nc
E
E
nc
Thankx for the help
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453784
06/17/13 12:03 AM
06/17/13 12:03 AM
I've bought way to many smaller pumps before buying the biggest and best Same thing on regulators
Re: Fuel flow thru reg? [Re: Cab_Burge] #1453785
06/17/13 12:09 AM
06/17/13 12:09 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here and the 500 is a beast for sure but I went w/the 300 knowing it should handle any n/a junk I throw it`s way and I wil never run a power adder.
Re: Fuel flow thru reg? [Re: Thumperdart] #1453786
06/17/13 12:12 AM
06/17/13 12:12 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
never say never.........
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453787
06/17/13 01:46 AM
06/17/13 01:46 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya but I`m dumb and stubborne and n/a`s a big enuff challenge as it is especially in the suspension dept.
Re: Fuel flow thru reg? [Re: Thumperdart] #1453788
06/17/13 04:12 AM
06/17/13 04:12 AM
I had a Magnafuel 300 pump, according to Mganfuel it was marginal for feeding 700 HP using E85 so I bought a 500 pump to be sure, I will probally end up with two Ron Terminators on it on E85 in the future so the 500 pump will be adequate to feed those via a sump tank control by a float for the belt driven pum to feed off of
Re: Fuel flow thru reg? [Re: Cab_Burge] #1453789
06/17/13 10:16 AM
06/17/13 10:16 AM
nc
E
E
nc
I retested the BG 280 this morning and had the same results as yesterday, gal in 19 secs & 7 psi, I let it run dead headed @ 18 psi for 15 min and the pump motor was a little warm but not hot, amp draw was 13 to 14 @ 13.5 volts , pump still a bit loud, When testing I removed one flex line from the fuel log feeding the primary bowl, The fuel blasts out the line like a fire hose, This is a 6an flex line that y,s together after the reg, From looking @ the fuel flow I cant see how the float bowl cant maintain the level from the amount of fuel flowing out the line, took the needle out and checked for a clog, All looked good, Could it be that the float is not reacting fast enough? The old needles were .110 & I went back with .120s thinking the bowl would fill faster, The Holley reg has a .220 restriction the .120 needles x 2 =.240, The BG reg is larger but I don't know the size, The fuel log is attached to reg with a inside dia of .340 @ the entrance to the log than y,s off to the bowels, is this too small?, a # 8an line will flow more volume @ 7 psi, Its just hard to figure that this small block can need this much fuel, in the past the engine consumed 1 gal in the 4 mins we ran to make a pass, that's from the pits to staging, a 200ft blast and back around to the pits, That's been consistent for the past few years, Anyhow has anyone had a problem with a 6an fuel log being too small?
Re: Fuel flow thru reg? [Re: emarine01] #1453790
06/17/13 11:27 AM
06/17/13 11:27 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my 520 ci. big block has 6an to the carbs and a holley big reg.it,ll run 9.30,s all day long with no prob.i have 120 needle and seat.
Re: Fuel flow thru reg? [Re: emarine01] #1453791
06/17/13 11:29 AM
06/17/13 11:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The #6 line wouldnt be the problem BUT the Y might be
on the small side... all the AN fittings I use I normally
drill them out some so its just inside the seating area
Re: Fuel flow thru reg? [Re: bonefish] #1453792
06/17/13 11:52 AM
06/17/13 11:52 AM
nc
E
E
nc
Is it 2 / 6an lines, one from each port from the reg, or one 6an split to 2 bowels?
Re: Fuel flow thru reg? [Re: emarine01] #1453793
06/17/13 12:13 PM
06/17/13 12:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
two seperate lines,one from each side of the reg.
Re: Fuel flow thru reg? [Re: emarine01] #1453794
06/17/13 12:33 PM
06/17/13 12:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used to set up motors on Pettis`s dyno and some of the baddest had #6 lines and we tried #8 w/zero difference however on my junk I went by the Mopar Bible and have #10 to reg. and #8 to each bowl.............
Re: Fuel flow thru reg? [Re: Thumperdart] #1453795
06/18/13 03:14 AM
06/18/13 03:14 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The restriction that all the fuel goes through in a basic Holley regulator is what, 1/16"? It is not enough to be able ot correctly feed todays high performance engines, I would say it's only good for about 600 hp. The old pro stockers didnät make that much power, and they had one reg for each carb.
Plynouth VIP '67 TT IC EFI
Re: Fuel flow thru reg? [Re: jyrki] #1453796
06/18/13 09:03 PM
06/18/13 09:03 PM
nc
E
E
nc
2 6an lines one off each reg port to each bowl seems to have solved the problem, But she source of the problem was a kinked line @ the 90* bend to the front bowl that was hidden by the SS cover on the fuel line, When I did the flow testing I dropped that line and straightened out the 90 to go in the bucket thus fixing the kink, I found the kink from cutting the line to shorten it This was nothing but a frustrating fire drill where the testing made no sense, Thankx to all for the help.
Page 2 of 3 1 2 3
