B-body pistol grip in a 69 dart #145369
11/03/08 10:18 PM
11/03/08 10:18 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline OP
Does anyone know if a 1970 b-body NON console Pistol grip shifter will fit in a 69' Dart or will I be smashing the dash. Pic's if possible. THANKS
Re: B-body pistol grip in a 69 dart [Re: 71DemonRON] #145370
11/03/08 10:41 PM
11/03/08 10:41 PM
San Jose, Ca. -- Honolulu, Hi.
Green_RB_Dart Offline
I have done it. You will NOT hit the dash. You WILL hit the steering wheel. I used a console handle. Which steering wheel are you going to be using? With the factory diameter wheel, the non console handle will hit the wheel when you look for reverse. The console handle locates the main vertical part of the shifter to the right to give you more clearance. You may still have to bend it away, as I had to. Do not have any pics handy. Email me if you really want to see one.
Don
Re: B-body pistol grip in a 69 dart [Re: 71DemonRON] #145371
11/03/08 11:17 PM
11/03/08 11:17 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Use a 71 B Pistol Grip. They are close to the same size as the original shifter.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: B-body pistol grip in a 69 dart [Re: Dan Brewer] #145372
11/04/08 10:24 AM
11/04/08 10:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said , the 71 B body bench seat handle would work the best .
