Re: HP B-body manifolds on 440 A-body
[Re: Jim_Lusk]
#1453667
06/16/13 11:09 AM
06/16/13 11:09 AM
RapidRobert
Hello Ori. What Jim said, go to big block darts' site. iirc due to a stackup of tolerances BB manifolds may or may not fit on the DR side & if they do it will be real tight & not sure if shortening the col sleeve will always take care of that. On the pass side lose the heat riser & need an angle cut to tilt the outlet closer to the block. I'd read up on it & drop the eng in without ex man studs & go from there
[Re: Jim_Lusk]
#1453669
06/17/13 12:34 AM
06/17/13 12:34 AM
Posts: 318 Fort Collins, Colorado
CoDart
Thanks guys! I will have to get a 440 first then get it sitting in there to check my clearances. May have to get out the ol dremel drill if necessary I sure hope they fit! Do I install the studs first or after the manifold is setting in place cause of room clearance? Ori
