Sure Am Glad I Pulled The Pan
#1453447
06/15/13 07:47 PM
06/15/13 07:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I pulled the oil pan today to fix 2 small oil leaks.. when it came down it fell out of my hand and hit the the floor(car was on the hoist) but no big deal... then I noticed my flapper door was all bent up.. looking at it closer I seen that it had flipped up and had been hitting the crank... I didnt think it would flip vertical but it did when it was in the car... I'm gonna change oil pumps just in case it caused any pump issues... I pulled 2 rod caps and 2 mains and everything was fine
Re: Sure Am Glad I Pulled The Pan
[Re: dOoC]
#1453449
06/15/13 10:30 PM
06/15/13 10:30 PM
MR_P_BODY
Good move ... but just curious ... how well do you have the doors sealing?
They are just metal on metal doors... I dont want them to seal I'm just slowing up the oil movement on decell... it has a gap around the pick up tube that will let oil by it sorta slowly... the doors open on acceleration allowing oil to the rear where the pick up is... with a baffle across the top to help keep it off the seal and the crank
[Re: MR_P_BODY]
#1453450
06/16/13 02:18 PM
06/16/13 02:18 PM
MR_P_BODY
I added a stopper for the door so it cant flip up... added a new oil pump for the "just in case" and put a rear main seal in it for the "just in case"... in a little while I'll go out and put the pan on... its all cleaned up and ready to go on
[Re: MR_P_BODY]
#1453452
06/16/13 10:07 PM
06/16/13 10:07 PM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I ask this because my boat pan has two doors that really don't seal all that well. PROBABLY one of the reasons why the guy who owned this before me FRIED two motors in it ...
[Re: Darryls-Demon]
#1453456
06/16/13 11:59 PM
06/16/13 11:59 PM
MR_P_BODY
So Mike will you have the car out on the streets this week to do some testing?
If the pan is sealed up then yes I should be putting some miles on it... I put the belts in yesterday but I still need to bolt the seats in.. thats only a few minutes
[Re: sixpackgut]
#1453458
06/17/13 09:20 AM
06/17/13 09:20 AM
MR_P_BODY
this is one of those posts that will stick in my mind. good catch
Its a pan that I built but I never figured about the door flipping up vertical and hitting the crank.. I sorta figured it would go 90* and that would be it... glad I pulled it for the small oil leak
[Re: MR_P_BODY]
#1453461
06/18/13 03:22 PM
06/18/13 03:22 PM
MR_P_BODY
Well my fix on the pipe nipple didnt fix the leak.. I'm gonna pull the remote fittings off the block and see if I can put it back to standard... now I have to find one of the oil filter plates... Mancini doesnt carry them (obsolete).. I might have to make one if I cant find one EDIT This engine HATES me... I was running it to see if the leak was fixed.. I had it running about 1/2 hour then I lowered it down and was looking at the top side to make sure where the leak was.. when the upper radiator hose blew off and covered me and the wall of the shop... I wonder why I do this sh17... I should pull this engine and put a stock 318 in it... rant off
[Re: MR_P_BODY]
#1453462
06/20/13 12:11 AM
06/20/13 12:11 AM
MR_P_BODY
I re-did the pipe nipple coming out of the block... I took my calipers to the hardware store and got the 3 largest brass ones they had... it went in much tighter than what I had in it... even with teflon tape... I pulled the pan and the header just for more room to get this damn leak fixed... I'll put the pan back on tomorrow... the header is already back on... at least the pan is easy to get on and off... about 10 minutes.. tomorrow will tell the tale EDIT the old steel nipple would bottom out at the end of the threads before it would get tight... this one is much tighter
[Re: MR_P_BODY]
#1453463
06/20/13 09:49 AM
06/20/13 09:49 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Why the heck did it blow off the upper hose?!?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#1453464
06/20/13 09:54 AM
06/20/13 09:54 AM
MR_P_BODY
I thought it was tight... but it wasnt.. the end of the clamp was hitting the fancy housing so the screw quit turning making me think it was tight.. oh well... but when I put it back on I gave it a good pull to make sure
[Re: MR_P_BODY]
#1453465
06/20/13 11:42 AM
06/20/13 11:42 AM
BBR
Amarillo, Texas
Good. I was thinking if it was making that much pressure in the cooling system, you have bigger probs than a small oil pan leak!
[Re: BBR]
#1453466
06/21/13 12:57 PM
06/21/13 12:57 PM
MR_P_BODY
I got the oil leak fixed it looks like... but I still need to jet this thing down.. still fat and the plugs are all loaded up with oil... I'm gonna pick up another set of plugs today and start fresh... it has 7"-8" of vac at idle in gear so the PV should be close.. sure hope it doesnt have a oil issue.. the pipes are still coated with oil(inside)... been trying to run it long enough to burn it out but I need to run it harder to clean them out... I dont see any oil when its idling... I tried the OD today for the first time.. I sure like that
[Re: MR_P_BODY]
#1453469
06/21/13 09:03 PM
06/21/13 09:03 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I got the oil leak fixed it looks like... but I still need to jet this thing down.. still fat and the plugs are all loaded up with oil... I'm gonna pick up another set of plugs today and start fresh... it has 7"-8" of vac at idle in gear so the PV should be close.. sure hope it doesn't have a oil issue.. the pipes are still coated with oil(inside)... been trying to run it long enough to burn it out but I need to run it harder to clean them out... I dont see any oil when its idling... I tried the OD today for the first time.. I sure like that
Saw the video Mike, and it looks like an oil problem.. Hope not but there is still time to fix if it is..
Chris..
[Re: Chris'sBarracuda]
#1453471
06/21/13 09:21 PM
06/21/13 09:21 PM
MR_P_BODY
Chris..
Its getting much better just running it... I still believe its my exhaust from the first engine.. being that my muffs are at the back bumper and on a angle I think there is a load of oil in them... I'm thinking of pulling them and spraying brake clean in them and dumping out what I can... with out running it on the road with some good exhaust flow it isnt getting hot enough to burn it out... nothing at idle and its getting better with reving it
[Re: MR_P_BODY]
#1453472
06/22/13 05:52 PM
06/22/13 05:52 PM
Posts: 8,677 Buford, GA
I_bleed_MOPAR
Buford, GA
And I thought I was the only one a car fought against. Sorry to hear you're having so much trouble with it. You know it'll be worth it when you're done though. BTW, Happy Birthday. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1453473
06/22/13 06:11 PM
06/22/13 06:11 PM
MR_P_BODY
Tim
Thanks on the B-day... I went to change the electric stat for the fan today... I bought one this morning and its my luck... it was bad out of the box.. they will have a new one tomorrow....I think I'm gonna pull the intake tomorrow to check the backs of the valves to see if they have oil on them
[Re: MR_P_BODY]
#1453475
06/22/13 07:55 PM
06/22/13 07:55 PM
Chris'sBarracuda
Arizona
Tim
I hope they are dry..
This is the engine with all the problems on the dyno??
I had one that just wouldn't get the rings seated, so I had to tear it down completely and re hone and used a standard tension ring and finally got them to seat.. Only happened to me one time over the years.
Happy Birthday..
Chris..
[Re: MR_P_BODY]
#1453476
06/22/13 08:05 PM
06/22/13 08:05 PM
dOoC
Florida STAYcation
x 2 .... P-guy ....and is that 1951 or 1851 ??
[Re: rt66jim]
#1453480
06/22/13 10:47 PM
06/22/13 10:47 PM
MR_P_BODY
Happy birthday Mike. Sounds like it is coming around. Just need to get it on a road where you can put the hammer down. Jim
Thanks... I hope to get out tomorrow afternoon and get a few miles on it
[Re: MR_P_BODY]
#1453481
06/22/13 10:55 PM
06/22/13 10:55 PM
