Re: Leaking pushbutton 727
[Re: sam64]
#1453423
06/17/13 10:44 AM
06/17/13 10:44 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
there is an oring on it.pan has to removed to trip the clip that the cable engages the valve body.
The pan doesn't have to be removed, the clip can be accessed with a flat blade screwdriver through the hole the cable goes in. I can post the instructions from the factory service manual if you need them, just don't remember which side the clip is on off the top of my head, been a couple years since I worked on mine.
[Re: hemi-itis]
#1453427
06/19/13 01:46 AM
06/19/13 01:46 AM
G_bob
Riverside, Ca
Hi G Bob,
I typically pull the pan whenever I disconnect the shift cable in case I have to readjust the cable. That way you can watch the valve body as the buttons are pushed to know if you've got it adjusted dead-on.
Bob
I was just saying you don't HAVE to drop the pan to access the clip to release the cable. Which was stated by another poster. I've only done it once, when I put my 64 together (using a 65 slip-yoke trans). So I'm no authority, but I followed the instructions in the FSM and got it installed and adjusted with no issues.
