Dual fans on one switch? #1453263
06/15/13 01:27 PM
06/15/13 01:27 PM
Saint Charles, MO
P
pleasantk Offline OP
P
Saint Charles, MO
I currently have an HHR fan on a Be Cool radiator that the core size is 27 x 18. So this fan leaves a lot of the core uncovered. It seems to work great at the track and allows quick cool down between rounds, but on the street I am having problems once the outside temps get over 85. Thinking of switching to a dual fan set up to cover the entire core area. My question is can I add a second relay for the second fan and run them both through the one switch that I currently have or do I have to have two switches?
Re: Dual fans on one switch? [Re: pleasantk] #1453264
06/15/13 01:45 PM
06/15/13 01:45 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I would set up the 2nd fan on a temp switch and relay to come on when one fan will not keep up.
"Just a Bracket car dressed up like a streetcar"
Re: Dual fans on one switch? [Re: pleasantk] #1453265
06/15/13 02:30 PM
06/15/13 02:30 PM
Penna
70satelliteguy Offline
Penna
" do I have to have two switches?"
No you do not have to have 2 switches. One can easily handle 2 relays!
MIke
p.s. I have one switch that turns on my 2 fans on ONE relay and the SAME switch also turns on a separate relay for my water pump.
Re: Dual fans on one switch? [Re: pleasantk] #1453266
06/15/13 02:31 PM
06/15/13 02:31 PM
Boise
Moparteacher Offline
Boise
Yes, you can wire a second relay to close with the one switch. Current draw on the relay coil winding is small, typically one to three amps. So you can run the second relay in parallel with the first.
Re: Dual fans on one switch? [Re: pleasantk] #1453267
06/15/13 03:32 PM
06/15/13 03:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The trigger on relays doesnt draw much at all(very
small amount) so yes you can
Re: Dual fans on one switch? [Re: MR_P_BODY] #1453268
06/15/13 06:54 PM
06/15/13 06:54 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I have 2 fans on 1 switch through a relay.
Fans are 26 amps to start and 21 to run. The relay is a 60 amp from Radio shack, so my amperage is less than 1 amp through the switch.
I went through the same thing and made a shroud, which helped. If you buy one of those kits, you'll wind up "making" a shroud anyway, with all the cutting.
I use a 2500 cfm puller and a small pusher between the grill and radiator.
Yeah, it's got a smallblock.
Re: Dual fans on one switch? [Re: 340B5] #1453269
06/15/13 11:45 PM
06/15/13 11:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use separate switches & relays for my fans.If one craps out I still have one working and a shot at getting home
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dual fans on one switch? [Re: hemi-itis] #1453270
06/16/13 12:21 AM
06/16/13 12:21 AM
Amherst,NY
challengermike Offline
Amherst,NY
I can tell you that 2 fans may not work with 1 controller that can control 2 fans.
I have a ford contour dual fan setup and it melts the hayden controller designed for 2 fan setup. I guess it pulls to many amps for it. I have tried 2 of them with the same result. So I wired mine with a toggle switch that controls the ground.
Re: Dual fans on one switch? [Re: challengermike] #1453271
06/16/13 12:35 AM
06/16/13 12:35 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
2 relays 1 switch, yes. All of the current will go through the relay contacts. The only current going through the switch is the relays coils which is very little. You do however have to make sure the relay contacts are rated high enough for the amps on the fans.
Re: Dual fans on one switch? [Re: hemi-itis] #1453272
06/16/13 12:37 AM
06/16/13 12:37 AM
V
viperblue72 Offline
viperblue72  Offline
V
You could jump the fan straight to the battery if you ever just wanted to get home.
Re: Dual fans on one switch? [Re: viperblue72] #1453273
06/17/13 02:15 PM
06/17/13 02:15 PM
Saint Charles, MO
P
P
Saint Charles, MO
Thanks for all the replies! I was pretty sure it shouldnt be a problem, but wanted to make sure. Currently have one 50 amp relay and will order another one this week.
Re: Dual fans on one switch? [Re: pleasantk] #1453274
06/17/13 07:07 PM
06/17/13 07:07 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Perhaps this may be the ticket. EBay Item 171049890081 if the link doesn't work.
http://www.ebay.com/itm/171049890081;jse...1#ht_253wt_1024
Re: Dual fans on one switch? [Re: viperblue72] #1453275
06/18/13 01:07 AM
06/18/13 01:07 AM
hemi-itis Offline
hemi-itis  Offline
Unless the fan motor has a stroke
