Auto to 4 speed conversion parts list help needed...
#145324
11/03/08 09:28 PM
11/03/08 09:28 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I'm in the process of gathering parts for swapping a four speed into my Dart Sport. I've already gotten the transmission, bellhousing, and have a Z-bar coming. Here's a list of the smaller parts I'm getting ready to order. I want to get all the little things bought first. The bigger things like the flywheel, pressure plate, disc, t/o bearing, shifter, and pedal assembly will have to wait until I work a bit more OT.
Please add to the list if I've left anything out. 1. Clutch adjuster kit. This has the adjusting rod, bushings, spring and clip. 2. Clutch linkage shaft kit. This has both ball studs and mounting brackets, Z-bar bushings, and the assorted clips and grommets. 3. Frame bracket. This is the weld on piece for attaching the ball stud to the frame. 4. Clutch pedal to torque shaft rod. 5. Clutch fork. 6. Dust cover. 7. Roller pilot bearing.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: Auto to 4 speed conversion parts list help needed...
[Re: 340727dart]
#145325
11/03/08 09:33 PM
11/03/08 09:33 PM
Posts: 1,411 Tallmadge, Ohio
Paul_B
Tallmadge, Ohio
8) Shifter Boot and trim ring 9) 4-Speed Carpet 10) 4-Speed Hump And the best part...
[Re: 340727dart]
#145326
11/03/08 09:40 PM
11/03/08 09:40 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Maybe a drive shaft(I think the 4-gear tranny is shorter) New rods and levers And you will have to put the heels and purse on E-bay because you will have a mans car now Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
