Ultimate Budget Paint Job - Metallics? #1453141
06/15/13 09:20 AM
06/15/13 09:20 AM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
I remember the long thread on Budget Paint Jobs, but don't remember any metallic colors. Is there a silver metallic paint that can be used?
Re: Ultimate Budget Paint Job - Metallics? [Re: Faust] #1453142
06/15/13 12:53 PM
06/15/13 12:53 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't think you can roll anything metallic, you'll see the roller lines and it'll look terrible.
I did the roller paint job though on a 81 Oldsmobile I had that I think turned out great.
Re: Ultimate Budget Paint Job - Metallics? [Re: 440newport] #1453143
06/15/13 04:18 PM
06/15/13 04:18 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Not a chance on metallic. Guys have trouble spraying metallic let alone rolling it. Can you say tiger stripes?
383, Hemi 4-Speed, AlterKtion, D60
Re: Ultimate Budget Paint Job - Metallics? [Re: Faust] #1453144
06/15/13 04:46 PM
06/15/13 04:46 PM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
Whats the budget? I did this Duster in my garage for about $650 total in material using Nason Acrylic Urethane. Not counting the stripes.
Re: Ultimate Budget Paint Job - Metallics? [Re: 440newport] #1453145
06/15/13 09:52 PM
06/15/13 09:52 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
I sort of guessed that, but wanted to check. Thanks, you guys.
Re: Ultimate Budget Paint Job - Metallics? [Re: T2R9] #1453146
06/15/13 09:56 PM
06/15/13 09:56 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Whats the budget?
Maybe you missed it. About two years ago there was a long thread on "budget paint jobs", the "budget" was $100.00.
My post is about a '67 Coronet Ihave kicking around, I want it to look better while it sits in the yard. That is why I wanted silver, which I expect are all "metallics".
Re: Ultimate Budget Paint Job - Metallics? [Re: Faust] #1453147
06/16/13 12:17 AM
06/16/13 12:17 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Metallics are tricky.
I was told that you cannot color sand the single stage metallic because it disrupts the flakes in the paint. There are 2 ways to get a good metallic paint job:
1) Be a good painter with single stage so you don't have to sand and buff it afterwards.
2) Spray it in base coat/clear coat, then sand and buff the clear.
Re: Ultimate Budget Paint Job - Metallics? [Re: Faust] #1453148
06/16/13 09:47 AM
06/16/13 09:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Silver paint without metallic in it...is just grey
**Photobucket sucks**
Re: Ultimate Budget Paint Job - Metallics? [Re: 70Cuda383] #1453149
06/16/13 11:53 AM
06/16/13 11:53 AM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Looking around the web, I see that Rustoleun makes silver paint that has been rolled on. Pictures aren't very clear, lots of poor lighting. There are reports that coverage is poor, one guy reports nine coats. I wonder how much he thinned it.
Re: Ultimate Budget Paint Job - Metallics? [Re: Faust] #1453150
06/16/13 12:38 PM
06/16/13 12:38 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I don't know what your circumstances are, but the cheap paint thread premise is that you trade a lot of effort and time for money. The cost is low, but it take a lot of time to prep, requires a lot more labor to lay on the paint, more time to work the surface between layers and the final result is not as long-lasting.
If you can spend a bit more, you could purchase a cheap siphon or HLVP gun, borrow or rent a compressor and shoot the same cheap paint for a metallic.
For double or triple, you can purchase a gun and some better paint and get better results that last longer.
http://www.autopaint18.com/html/paint_kits.html
