Can't seem to catch a break
#1453035
06/15/13 12:25 AM
06/15/13 12:25 AM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Well, I'm still chasing a very stubborn oil leak from the timing chain cover area. This latest round I picked up a new cover and went to install it tonight until I found a substantial amount of this caked up in the fuel pump eccentric:
A magnet will pick it up. Is this something I should be concerned about?
Thanks...
Re: Can't seem to catch a break
[Re: MarkZ]
#1453038
06/15/13 01:13 AM
06/15/13 01:13 AM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
NO that's not normally found in ANY healthy engine.Flat tappet cam?
Yeah, Comp XE-274 with Edelbrock heads.
Ummm...I'd be concerned. Do you have a magnetic drain plug? Pull it and look.
[Re: MarkZ]
#1453040
06/15/13 01:26 AM
06/15/13 01:26 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I do. This is really making me worried. Guess I'll drain the oil and cut the filter open in the morning.
sounds like a good plan.
[Re: MarkZ]
#1453041
06/15/13 02:50 AM
06/15/13 02:50 AM
RapidRobert
I'd suggest a thorough visual in the timing chain area & if good there then pull the valve covers. keep going till you find out where the problem is at that is producing the shavings. Holler how it goes. You very well might need to tear it down & clean everything then go back together with that amount of metal showing but first find the problem. EDIT see if the timing cover flat shows signs of the eccectric rubbing on it. A stackup of tolerances can put em together. A thicker gasket will solve it
[Re: RapidRobert]
#1453042
06/20/13 08:20 PM
06/20/13 08:20 PM
MarkZ
Worthy
Worthy
Well, a bit of an update. I cut the filter open, fished a magnet through the pan, popped the valve covers, and didn't find anything. It beats the hell out of me. There was no out of the ordinary noise coming from the valve train prior to pulling the cover off either. The backside of the original timing cover looks to be in good shape as well.
[Re: MarkZ]
#1453043
06/20/13 11:12 PM
06/20/13 11:12 PM
Posts: 2,531 God's Country Maryland
GODSCOUNTRY340
Is there an oil slinger on the crank? That fuel pump eccentric needs a good supply of oil thrown onto it to keep the fuel pump arm from eating it.
