Carburetor problems with heat soak #1453005
06/15/13 12:12 AM
06/15/13 12:12 AM
Connnecticut
acesneights Offline OP
Connnecticut
My 440 BB in my Travco had a Thermoquad on it. The acclerator pump was shot and the age of the carb was unknown although it had a Holley rebuild sticker on it. I decided easier to just throw a new edelbrock performer on it. Well since I did the fuel perculates really bad giving an awful gas smell about 15 mins after shutdown. Also makes it diffcult to start. After reading up on this being a common issue with the Edelbrock, I returned it and bought a reman Holley Spreadbore direct TQ replacement. It runs really good but still having same issue. I have an insulator gasket under it. Any ideas ? I was told nothing I can do and that the reason the TQ didnt do it was the plastic bowls but that they are dangerous and can crack and spray gas all over.
I was thinking about putting it back on but the Holley really runs sweet. it gets the gas stink also but will start when hot.
I hav the factory cast iron spreadbore intake ? Would an aluminum intake help ?
I really didn't want to dump a ton of money into this motor as It has 94k miles on it and I plan on replacing it with a Cummins Diesel.
1975 Dodge Travco 440 BB 1972 Dodge Travco 318 SB
Re: Carburetor problems with heat soak [Re: acesneights] #1453006
06/15/13 02:08 AM
06/15/13 02:08 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
1/2" phenolic or wood spacer between the manifold and carb should help greatly if you have room.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Carburetor problems with heat soak [Re: acesneights] #1453007
06/15/13 02:11 AM
06/15/13 02:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Electric fuel pump with a return regulator or self learning EFI.
Re: Carburetor problems with heat soak [Re: acesneights] #1453008
06/15/13 02:37 AM
06/15/13 02:37 AM
blocked heat riser. non ethanol gas. wood spacer (laminated baltic birch?)
Re: Carburetor problems with heat soak [Re: acesneights] #1453009
06/15/13 02:48 AM
06/15/13 02:48 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Insulate any metal fuel lines as well as keeping them away from heat sources,an electric fuel pump with return,heat shield between carb and manifold would be the starting point.
Re: Carburetor problems with heat soak [Re: acesneights] #1453010
06/15/13 08:10 AM
06/15/13 08:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes a aluminum intake with either the heat risers blocked or not even there like my victor 340 intake with no heat risers and a air gap underneath. It does great in hot weather and I run a edlebrock carb.
Get rid of the original heavy intake with heat risers.
Re: Carburetor problems with heat soak [Re: acesneights] #1453011
06/15/13 09:36 AM
06/15/13 09:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Go back to the T/Q and save your $$$$,accelerator pumps are cheap!!
Re: Carburetor problems with heat soak [Re: 62maxwgn] #1453012
06/15/13 10:12 AM
06/15/13 10:12 AM
Connnecticut
Connnecticut
IS non ethanol gas available ?
I have never seen it around here. It all has 10% in it. I bought some treatment for ethanol from Stabil. Figured it would be good for the generator too as that runs off same fuel tank.
I can say where the choek mounted it get's very hot. I had left the ground wire from the TQ choke laying there and it melted. I think it's the heat coming off the manifold more than the fuel lines. I think it's boiling the fuel in the bowl after shutdown. I guess an aluminum intake is probably the best way to go. A good spreadbore pheolic spacer was like 80$. That is alomst halfway to a new intake. I wish I could find a used one.
Re: Carburetor problems with heat soak [Re: acesneights] #1453013
06/15/13 07:44 PM
06/15/13 07:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don't even think about the non ethanol gas use, though it would be nice ethanol is in the fuel pretty much everywhere , finding non ethanol is not easy , or cheap.
Also an Alum intake with the heat riser blocked is not the answer either, there are many still combating the issue wit han alum intake and the heat riser blocked.
You need to sheild the carb from as much heat as possible and get cool air flowing around it to keep it warm.
The electric fuel pump isn't the total answer but it will put fuel in the carb faster than the mechanical on the side of the engine and it will take care of the restart by filling the carb faster.
Re: Carburetor problems with heat soak [Re: JohnRR] #1453014
06/17/13 12:46 PM
06/17/13 12:46 PM
Connnecticut
Connnecticut
I toyed with the idea of putting a marine bilge blower in and piping it to the intake area. The problem is that this is a motorhome so it also gets zero airflow.I did it yesterday and even once I got it started it was running funny like idling poor until I drove it for abit.
Re: Carburetor problems with heat soak [Re: JohnRR] #1453015
06/17/13 12:52 PM
06/17/13 12:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
IMO, if this is the case, then I would predict that they are lean, real lean under power making too much heat. Did the OP richen it up and see if it helped?
Ethanol fuel needs to be run richer to keep the a/f ratio the same as non ethanol fuel.
Re: Carburetor problems with heat soak [Re: Challenger 1] #1453016
06/17/13 01:29 PM
06/17/13 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also an Alum intake with the heat riser blocked is not the answer either, there are many still combating the issue with an alum intake and the heat riser blocked.
One car in particular was run on a chassis dyno and the carb adjusted so I don't think it being lean is the issue , but you never know.
The OP , I don't know what he did.
Re: Carburetor problems with heat soak [Re: acesneights] #1453017
06/17/13 01:32 PM
06/17/13 01:32 PM
dogdays Offline
dogdays  Offline
First of all let's put something to rest.
"I was told nothing I can do and that the reason the TQ didnt do it was the plastic bowls but that they are dangerous and can crack and spray gas all over."
The three most dangerous words on this board are either "I was told" or "I have heard".
Now on to the phenolic bowls. They have been known to warp, but the idea that they should be avoided because they'll crack and spray fuel everywhere is just rubbish.
Now on to ethanol in the gas. Thank you to JohnRR for pointing out that it's almost impossible to buy gas without ethanol in it. It's a federal requirement for areas that cover about 90% of the US population. Also, fuel manufacturers change the evaporation rate "Reid vapor pressure" for summer or winter. So, for example, if your motor home has a load of winter gas in it, it will evaporate faster in the summer and give you more problems. On the other hand, a load of summer gas can mean a very hard-starting car in the winter. Fuel has to be in vapor form in order to light off.
So maybe the easiest thing to do would be to rebuild the Thermoquazd one more time.
Your idea of a bilge blower is NOT a bad idea.
An Edelbrock wood spacer would help. Heck, two would help more, and look at heat shields to block off radiant heat between engine and carb.
Blocking off the heat riser under your stock manifold would help.
As far as heat conductivity goes, aluminum conducts best. Then the Holley zinc body, then cast iron, then insulators like wood or plastic. So replacing your cast iron manifold with an aluminum one would increase the heat conducted to your carb.
Check out the new Barry Grant Street Demon with the "space age plastic" bowl. According to a race shop board member, this carb is tremendous. Maybe that's an option, too .
R.
Re: Carburetor problems with heat soak [Re: dogdays] #1453018
06/17/13 01:38 PM
06/17/13 01:38 PM
Cincinnati, Ohio
Cincinnati, Ohio
The only reason I suggested aluminum is because one can be had with no heat risers.
Lean is mean and makes heat, do you really need that on the street? Sure on a dyno your gonna go lean to make the most power.
A dyno does not have all the answers, many guys can tell you that after tuning on dyno.
Re: Carburetor problems with heat soak [Re: Challenger 1] #1453019
06/17/13 03:59 PM
06/17/13 03:59 PM
P
Paul_Fancsali Offline
P
In 1987-88 Dodge installed electric fuel pumps in the B 350 vans that were stalling due to heat or no start after sitting They also used a higher output mech pump on the 360s The carb you are using is a emission carb designed for the 360 of the 80s. You can consider a Chrysler base Rochester carb they have thicker heat gasket that will isolate the carb somewhat. Despite what you may hear the q jet is just as good if not better the the TQ and I have used and have both carbs. The gas mileage on the Q is better on average. By the way if the carb you have is the emission version Holley the sec will never open all the way it comes with a super heavy black spring, in vac pot standard. But for now keep what you have and insulate the lines and get a 1 inch spacer{not metal or aluminum and put a low output electric pump on the van
Re: Carburetor problems with heat soak [Re: acesneights] #1453020
06/17/13 04:08 PM
06/17/13 04:08 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I run schitznit fuel spiked with 110...
An aluminum M-1 with a thick base-gasket under a 750 Edelbrock AFB...
It's supplied by a 440 HP mechanical fuel-pump...
No vapor separator-a later filter with return to the vapor canister...
The correct non-vented cap...
No problems...
Re: Carburetor problems with heat soak [Re: RSNOMO] #1453021
06/17/13 04:14 PM
06/17/13 04:14 PM
Connnecticut
Connnecticut
I think I should clarify, the issue is not while I am driving it. it is fine. It's when I shut it off, the residual heat form the motor appears to be boiling the gas out of the carb. That was why I thought maybe Alum intake would be better becuase I know it conducts heat better but it also cools down quicker. I have room for about 1 inch of spacer before the carb hits the engine cover.
I could probably fix the TQ myself. It just needs an accel pump.
I am not sure which Holley. All I know is it looks like a speadbore version of a 600 vac sec and the guy told me it was a specific aftermarket replacement for the TQ that is no longer made. I don't think it's an emmisions carb but I will take some pics and post them.
This all started after I took the TQ off. The TQ had a major stumble/flat spot. The TQ had a Holley Rebuild sticker on it which I "was told" is a good version of it.
I have worked on carb stuff over the years but I will confess I am more of a diesel guy.
Re: Carburetor problems with heat soak [Re: acesneights] #1453022
06/17/13 04:24 PM
06/17/13 04:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If this is your only gripe then put an electric fuel pump on it and be done. No matter how you try to insulate the carb the fuel is going to evaporate long before the engine compartment is cool enough to not cause an issue.
Re: Carburetor problems with heat soak [Re: acesneights] #1453023
06/17/13 04:25 PM
06/17/13 04:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
From my experience with my combo over the last 20 years...
Unless yer gonna ice-down the carb, the percolation issue is reduced with the addition of 'real' fuel...
Excessive heat is the enemy...
I have a 6-quart pan, in addition to a deep trans pan w/cooler, and a 3-core rad...
When I shut it down, it's at 180...
Not 195, not 210...
An electric fuel-pump is not a necessity, and not necessary...
It's your call...
I'm only offering what's worked for me...
Re: Carburetor problems with heat soak [Re: RSNOMO] #1453024
06/17/13 04:53 PM
06/17/13 04:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I run a stock carter AVS on my 69 383 dart , I haven't driven the car in 7yrs but I never had a problem with gas percolating ...
