727 Torqueflight transmission leaking from pivot pin
#1452971
06/14/13 10:34 PM
06/14/13 10:34 PM
Posts: 53 Connnecticut
acesneights
Connnecticut
Hello, new to forum. I have a 1975 Dodge Travco with a 440 and a 727. The transmission is leaking. I thought it wa the pan gasket so I chaged it twice before I found the leak. It was hard to see but from what my searching has revealed is that it is a pivot pin for the reverse band and it has an o ring (or possibly 2) and that is where it is leaking. My question is how to fix it and fast. We are supposed to go camping this weekend. Being that this is a Dodge M500 chassis it is very accessible. If I cn remove the tailhousing without much difficulty do I need to drop the pan as well and does the valvebody need to come out ? I have never dissasembled a Chrysler Valve body. ONly GM TH350/400 and it ha been a number of years since that. Thanks for any help. I am a diesel truck mechanic so have decent ability but don't normally mess with automatics.
1975 Dodge Travco 440 BB
1972 Dodge Travco 318 SB
Re: 727 Torqueflight transmission leaking from pivot pin
[Re: acesneights]
#1452972
06/14/13 10:43 PM
06/14/13 10:43 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
To quick fix it, spray it all off with a good cleaner and carefully apply one of the Permatex ATF resistant rtv silicone sealers on it. Then, another day, remove the extension housing, drop the pan and pull the valve body and get to the lower band apply linkage and pull the pin out and fix it with new o-rings. Tom
[Re: acesneights]
#1452977
06/15/13 02:04 AM
06/15/13 02:04 AM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Thank you for the responses. That is what I will do although getting it tipped up may be difficult. it weighs 14,000 lbs...
Do you have access to an incline you can back it up and chock the wheels to help hold it ?
[Re: acesneights]
#1452978
06/20/13 11:34 PM
06/20/13 11:34 PM
Posts: 386 Maryland
reno340
Maryland
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
