Converting TO A/C #1452917
06/14/13 07:33 PM
06/14/13 07:33 PM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
I'm wanting to put A/C in my 72 NON A/C truck. I found a 77 parts truck. Will the dash and all other accessories bolt in? I want to run with my original dash pads and gauges...
OR does someone have a link to a decent under dash unit? Looking to keep it around $500
Re: Converting TO A/C [Re: magnum440d100] #1452918
06/14/13 07:47 PM
06/14/13 07:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You will have to use all the 77 dash parts. 72-74 are different.
Re: Converting TO A/C [Re: NITROUSN] #1452919
06/14/13 08:43 PM
06/14/13 08:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Isnt the heater/ac box hole larger for an AC truck than a non AC truck ??
I am truckless..
Re: Converting TO A/C [Re: NITROUSN] #1452920
06/14/13 08:44 PM
06/14/13 08:44 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The 74 dash pad and glovebox lid and gauges should work on the 77 dash frame.
Re: Converting TO A/C [Re: 76dodgeboy] #1452921
06/14/13 09:37 PM
06/14/13 09:37 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Harry,they will work, I used to like the 72-74 dash bezel cause it's easier to do in aluminum so I put the 72-74 pad & glovebox door on almost everyone of them that I owned for me
Re: Converting TO A/C [Re: 340SHORTY] #1452922
06/14/13 11:02 PM
06/14/13 11:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Nope it will bolt right in.
Re: Converting TO A/C [Re: 76dodgeboy] #1452923
06/14/13 11:04 PM
06/14/13 11:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They will but there are differences. You can also cut the older dash openings to fit the a/c duct work. I have done that a few times.
Re: Converting TO A/C [Re: NITROUSN] #1452924
06/14/13 11:19 PM
06/14/13 11:19 PM
woodcrest, CA
woodcrest, CA
That sounds doable. As long as I have a template/other dash just INCASE haha.
