Help! Clutch Free Play Adjustment #1452516
06/13/13 07:48 PM
06/13/13 07:48 PM
NY
Beep Beep Offline OP
NY
Does anyone know what the correct air gap is on a diaphragm type clutch? I am running a American Powertrain Clutch. What gap should I have between the throw out bearing and the pressure plate fingers?
Re: Help! Clutch Free Play Adjustment [Re: Beep Beep] #1452517
06/13/13 08:08 PM
06/13/13 08:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
.060" gap is what is usually used in lieu of the factory giving you a number. As for the throwout bearing, never heard of a number there, just as long as it doesn't ride on the fingers.
Don't be the exception.
Re: Help! Clutch Free Play Adjustment [Re: Supercuda] #1452518
06/13/13 08:33 PM
06/13/13 08:33 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Help! Clutch Free Play Adjustment [Re: 68LAR] #1452519
06/14/13 12:47 AM
06/14/13 12:47 AM
NY
NY
Thanks guys.
Re: Help! Clutch Free Play Adjustment [Re: Beep Beep] #1452520
06/17/13 02:10 AM
06/17/13 02:10 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I'm surprised it calls for a gap.
Most anything built in the last 20 years has a slight preload.
Re: Help! Clutch Free Play Adjustment [Re: Beep Beep] #1452521
06/17/13 04:23 AM
06/17/13 04:23 AM
You may need to install a clutch stop bumper to keep from over centering the diaphram pressure plate espcially at high RPM , I like to have at least .060 air gap between the disc and the plate or flywheel and the same on the throwout bearing to the fingers on the pressure plate Absolutely no contact on the bearing to the fingers with the clutch peddle all the way out If it touches it will wear the bearing and maybe the fingers out real quickly
