Help Doc Diff -- Pinion Nut Different #145244
11/03/08 06:51 PM
11/03/08 06:51 PM
in
P
pgccp Offline OP
pgccp  Offline OP
P
in
Anybody
I bought a Ring and Pinion Ratio 3.55 with a fine spline my oem gear is course spline the nut and washer are smaller what size nut do I need if Doc Diff sees this what is your phone # Need parts. Thanks Bob
Re: Help Doc Diff -- Pinion Nut Different [Re: pgccp] #145245
11/03/08 09:38 PM
11/03/08 09:38 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Try this, measure the OD of the threaded part
of the pinion, then count the number of threads
over an inch that will tell you what you need.
Re: Help Doc Diff -- Pinion Nut Different [Re: pgccp] #145246
11/04/08 04:51 PM
11/04/08 04:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 10-spline pinion uses a 3/4"-16 thread while the 29-spline uses 7/8"-14.
