Stage 6 Max Wedge Combos #1452396
06/13/13 05:58 PM
06/13/13 05:58 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i'm looking at buying a 470 stroker with Stage 6 heads from a member on here. anybody running the Stage 6 head able to post their combo with a pic of it please. i'm buying this motor on behalf of a friend who will be using my 'cuda in a night streetcar racing series. would be cool if they could see some combo's with these heads. thanx
Reb.
Re: Stage 6 Max Wedge Combos [Re: rebel] #1452397
06/13/13 10:15 PM
06/13/13 10:15 PM
Arizona
Chris'sBarracuda Offline
Arizona
Mine was a 500" low deck.
Heads were done by Don Studley.. (Major Project)
Pedestals milled off and used rocker stands for geometry because longer valves used.
2.18 x 1.81.. Don't know flow numbers, Don never told me..
Heads were milled quite a bit for compression, 13:1 with flat top and 1105 head gasket.
Indy 400-3 intake 1050 Dom. (9375)
Cam Motion CM-1 cam 276-283 .737/.672 w/ 1.6 rockers.
Car weighed 2950# Powerglide w/9" super class converter 6200 stall
4.30 gears.. 14 x 32 M/T tires
Went best of 9.25 @ 143 in Phoenix.. Never ran @ sea level though..
Here's a video.. Before wrecked..
http://www.youtube.com/watch?v=kCePPblwlGA
Chris..
Re: Stage 6 Max Wedge Combos [Re: Chris'sBarracuda] #1452398
06/14/13 03:59 PM
06/14/13 03:59 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
mopar mega block 4.5 bore, 4.25 stroke, stage 6 max wedge head, 1050 dom, .667 roller
8.87/155 mph
http://drag.race-cars.com/carsales/other/1295227607/1295227607ss.htm
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Stage 6 Max Wedge Combos [Re: 440lebaron] #1452399
06/15/13 11:56 PM
06/15/13 11:56 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I have a 400 based 451 with Max Wedge size Stage VI heads (flow 310ish), Mopar 590 cam, Indy 440-3 intake, Quick Fuel 1050 Dominator. With my current piston, I'm a little over 13:1. With me in it the car goes 3300lbs the bests are in my signature.
When i was researching heads I remember reading the comment that the Stage VI's were very well suited for the smaller displacement engines 451/470 but based on the previous post they seem to do fine on the larger displacement stuff also.
My only compliant is the amount of oil they hold near the bottom side of the valve cover and that is even after I have cut some reliefs in the spring pockets. However in the scope of things very very small price to pay.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
