Re: what fuel pressure regulator do I use?
[Re: James74]
#1452285
06/13/13 03:10 PM
06/13/13 03:10 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
88 dodge w-150. Swapped out the 318 for a 440, which means I went from TBI to carb. Still using the stock TBI in tank fuel pump. I know this needs a bypass type regulator, but I wasn't sure if a regular carb style one (7psi) would work? IIRC, the pump is rated at 60 psi...
Call Aeromotive, Magnafuel, Weldon and the other good(not Aeroaspace ) fuel system manufacturers to see if they have a regulator that will work the way you want it to
