For almost a year I have been having a problem with starting my Barracuda. It was intermittent so it was difficult to diagnose but I have finally come to the conclusion that my positive battery cable has somewhat rotted out on the inside causing the problem. When I turned it to a certain angle the car started right up. I never knew it was possible for a cable to rot out/have a bad connection on the inside.
I bought the current cable about 6-7 years ago and it is a repro of the factory style cable. I remember paying About $40 for it. I checked with Classic Industries and they want $127 for a made in America repro. Then I did some searching on line and found others that had the same part under $50 but it didn't say made in America. I'd hate to buy the expensive version and have that one rot out in 6 years. The original Chrysler cables lasted longer than that.
Anyone have the same dilemma? Are the cheaper cables the same quality or are they inferior? What would you guys do? Thanks in advance.
