440 source 1.6 aluminun roller rocker reviews WANTED #1452032
06/13/13 12:37 AM
06/13/13 12:37 AM
Uranus
strokerchall Offline OP
Uranus
anyone using/used these?
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452033
06/13/13 12:40 AM
06/13/13 12:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452034
06/13/13 02:33 AM
06/13/13 02:33 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Proceed at your own risk...
Just my $0.02...
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452035
06/13/13 12:38 PM
06/13/13 12:38 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Do you consider yourself a " gambling man" ?
RIP Monte Smith
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: CompWedgeEngines] #1452036
06/13/13 01:12 PM
06/13/13 01:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
MAN ???
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: JohnRR] #1452037
06/13/13 06:23 PM
06/13/13 06:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't believe John is sitting so quietly !!!!
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: Stanton] #1452038
06/14/13 01:12 AM
06/14/13 01:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have been threatened that if I don't have first hand info that I am not allowed to point out what has happened to others that have posted their tales of woe.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: JohnRR] #1452039
06/14/13 03:36 AM
06/14/13 03:36 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Without doing a search on the topic, I suppose these are prone to failures?
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: Jjs72D] #1452040
06/14/13 07:16 AM
06/14/13 07:16 AM
michigan woods
imfixinmopars426 Offline
michigan woods
most everything is prone to fail...just how much is the question,and you only hear of the failures,and never the successful ones.hard to gauge,but my dad always told me you get what you pay for,and this I find to be true. I would hate to skimp on rockers...lots going on there!
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: Jjs72D] #1452041
06/14/13 10:45 AM
06/14/13 10:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: JohnRR] #1452042
06/14/13 11:43 AM
06/14/13 11:43 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I would believe most are skeptical with heavy spring load applications but not with street applications. We should use Ed Pink's guarantee policy once it starts you own it. There are no guarantees with any performance parts no matter who the manufacturer is.
MLR426
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: MLR426] #1452043
06/14/13 12:35 PM
06/14/13 12:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
MLR426
The issue with the alum. body offshore rockers was the spindle the roller tips turns on is brittle and is breaking. Once broken the rocker body design can/will push on the retainer and pop the valve locks off the valve, the valve drops into the cylinder and one can guess the rest.
Rockers are one place you shouldn't really skimp as even these type rockers have broken with light hyd. flat tappet spring pressures.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452044
06/15/13 09:56 AM
06/15/13 09:56 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Just add this to the other 100 million "Are 440 Source (fill in the blank) any good?" posts....
When are people going to finally wise up?
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: Commando1] #1452045
06/15/13 04:58 PM
06/15/13 04:58 PM
Uranus
Uranus
so i'm guessing no one has used these and can give an honest review?
I'm asking because an engine i'm buying has them installed by hughes engines
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452046
06/15/13 07:39 PM
06/15/13 07:39 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I don't know about the 1.6's but the 1.5's I had from 440 source had seriously galled the rocker shafts when I removed them at 200 or so street miles with a moderate hydraulic roller cam. Most of the roller tips felt very rough on the axles. I tossed them and replaced them with Hughes. Around 1000 miles, no problems.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452047
06/15/13 07:40 PM
06/15/13 07:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hughes as in Dave Hughes ?
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: strokerchall] #1452048
06/16/13 12:32 AM
06/16/13 12:32 AM
Portland, Oregon
Digger73 Online rolleyes
Digger73  Online Rolleyes
Portland, Oregon
Don't know about the 1.6 rockers but, we ran a set of 1.5s on the wife's 'Cuda. We ran them with a Crane solid roller cam for 4 years with no problems. Never any issues with the shafts or the roller tips.
The only reason we are not running them now is that the heavy spring loads caused the bottom side of the rockers to crack. This is the same thing that happened to the Crane gold rockers we first tried.
The engine by the way is a 440 Source stroker 512" that has been running and raced for 6 years now. I am sure there is a good reason to bash 440 Source stuff but, not all of us are made of money and have to try to save money where we can. If that means that I have to go against the popular ideals and buy from someone that I can afford their parts so be it. I normally don't rave on but I just felt I had to vent.
Mike (Digger73)
I live with fear everyday but, sometimes she lets me race!
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: CompWedgeEngines] #1452049
06/16/13 07:02 AM
06/16/13 07:02 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
As with many parts it seems they are neither 100% good nor 100% bad. So.....
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: Digger73] #1452050
06/16/13 08:39 PM
06/16/13 08:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike (Digger73)
A solid roller usually is speced for high spring pressure , this is not the place for a solid body unbushed alum. rocker ... or an unbushed iron rocker for that matter. If the Cranes broke I wouldn't have expected a CCJ rocker of the same design to be any better.
That said you must not have had high spring pressures because ccj rockers have failed being run on hyd. flat tappets.
Re: 440 source 1.6 aluminun roller rocker reviews WANTED [Re: JohnRR] #1452051
06/17/13 01:57 AM
06/17/13 01:57 AM
Portland, Oregon
Portland, Oregon
Mike (Digger73)
Not sure what is considered to be high spring pressure but the spring loads we run are 223 closed and 576 open.
Mike (Digger73)
