Re: Cast or Forged Pistons [Re: NAS Backyard] #1451982
06/14/13 03:37 PM
06/14/13 03:37 PM
Cast aluminum pistons will break and disentigrate (SP?) when coming in contact with any foriegn parts, small nuts, washers or spark plug tips or any other hard parts from any source, even detonation Forged pistons will not disentigrate, they will melt and get beat up but they won't end up in the oil pand in little bittie pieces I like and use forged piston on any build I can, I have sent customers away that wanted me to use the hypertutics pistons in there motors instead of forged ones Egge parts are way expensive and not real good quality, I think they buy from the cheapeast supplier
Re: Cast or Forged Pistons [Re: NAS Backyard] #1451983
06/14/13 04:38 PM
06/14/13 04:38 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
CAST!! They will work with no problems.I'm using cast in my 440 ..runs 11.30's.
Nautilus Racing-
Re: Cast or Forged Pistons [Re: Cab_Burge] #1451984
06/14/13 04:47 PM
06/14/13 04:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I have to chuckle...
Here's a seasoned veteran describing the pitfalls of using cast...
All real, seen it myself...
Then another take...
'Cast will work with no problems'...
I love the internet...
Re: Cast or Forged Pistons [Re: RSNOMO] #1451985
06/14/13 05:25 PM
06/14/13 05:25 PM
dogdays Offline
dogdays  Offline
Literally hundreds of millions of cars have been built with cast pistons. I am sure that tens of thousands have gone down the strip in less than 13 seconds. I have seen some pretty beat up cast pistons that have been dinged by screws, nuts, valves, etc. They generally do NOT disintegrate from this kind of abuse.
Put them in a high rpm motor or run a lot of NOS past them, especially with lean A/F ratios, and they'll come apart. But I have in my collection some very high dollar forged pistons, 2618 alloy, that are pretty melted too.
Face it, for the kind of use this 394 Olds is going to see, almost any piston will get the job done.
Now to the real question, has the OP followed my lead on Doc Frohmader's 394 olds buildup yet? Doc says he took 303 grams out of EACH rod/piston combo. That's 2/3 of a pound out of EACH hole. That is worth considering for any engine.
R.
Re: Cast or Forged Pistons [Re: NAS Backyard] #1451986
06/14/13 05:38 PM
06/14/13 05:38 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The engine is 394 Oldsmobile
If you want good advice for that motor ask questions on the HAMB
http://www.jalopyjournal.com/forum/forumdisplay.php?f=5
Re: Cast or Forged Pistons [Re: Lefty] #1451987
06/14/13 07:11 PM
06/14/13 07:11 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
Yea, I was working my way over to the HAMB but my piston vendor posts over there hehe !
As far going the hybrid route with other parts, my crankshaft is already being drilled for the pilot bearing. I will call the guy in PA. Thanks!
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Cast or Forged Pistons [Re: RSNOMO] #1451988
06/14/13 07:49 PM
06/14/13 07:49 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
...take it from an Xpert ... if they work on the bEAST-side ... they will work ANYwhere !
Re: Cast or Forged Pistons [Re: dOrk !] #1451989
06/15/13 10:24 AM
06/15/13 10:24 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I ran a 13.5:1 SB with KB hyperutectic pistons. No problems if you follow the ring clearance instuctions. I agree with Cab, but this is a street motor that should never see 6K, detonation or any other issues.
Re: Cast or Forged Pistons [Re: RSNOMO] #1451990
06/16/13 09:56 AM
06/16/13 09:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how the piston fails really doesn't matter, if your tune is off and you get detonation, bad things happen regardless of cast vs forged, the pounding that the bearings take can force you to have to rebuild the engine, regardless of what happens to the pistons.
hard metal goes down the intake and starts pounding a piston, again, doesn't really matter at that point if you have a forged or cast piston...it's time for an engine rebuild.
I will echo that for the mild build the original poster is looking at building, I don't see much of a reason why he NEEDS forged pistons over cast or hypers.
it's not like he's talking about feeding it 15 psi of boost with meth injection
**Photobucket sucks**
