Re: Hemi Flywheel . Are these made anymore?
[Re: TrWaters]
#1451807
06/12/13 05:01 PM
06/12/13 05:01 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
I haven't had any luck finding a source. 426 hemi 130 tooth 50 lb flywheel.
50lb flywheel, why so heavy ?
I think the std for the heavy wheels these days is 30lb , like the one in the link above me ...
[Re: TrWaters]
#1451809
06/12/13 05:57 PM
06/12/13 05:57 PM
JohnRR
U.S.S.A.
A 50 lb flywheel gives me the thickness needed to adapt to this specific application... by a bit of re-machining. It will be approximately 30 lbs when I am done. An over the counter 30 lb will not work.
What year and application used a 130 tooth 50lb flywheel ?
[Re: TrWaters]
#1451810
06/12/13 06:10 PM
06/12/13 06:10 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I know I have a really heavey steel 130 tooth in my hoard. I'll weigh it tonight.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JohnRR]
#1451811
06/12/13 06:31 PM
06/12/13 06:31 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
back in the late 60's 50lb was the ticket
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1451812
06/12/13 06:35 PM
06/12/13 06:35 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
