What would make a poly strut rod bushing fail?
#1451575
06/11/13 11:37 PM
06/11/13 11:37 PM
Posts: 3,344 Central TX
roe
Central TX
Its only been on the car since January or so of 2012, and hasn't been driven a lot. The bolts were torqued down after the cars weight was on the suspension and the ride height set. Driver side front strut rod bushing just fell off. I was driving and noticed, out of nowhere, it started pulling to left when braking. Limped it home and started checking, and noticed the front on was gone.
Of course none of the parts stores had them in stock, but rock auto did beat all their prices on poly by almost $30, Moog parts. Now its a waiting game for it to show up. Going to just replace them all.
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: What would make a poly strut rod bushing fail?
[Re: roe]
#1451576
06/12/13 12:30 AM
06/12/13 12:30 AM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I've run cars hard with poly bushings and have seen some bad issues that some would say can't happen...Movement between the shell and poly insert...Split and disintegrate....Had one set get soft like the urethane was breaking down after about 30,000 miles... Usually when they split and/or fail like what you're describing A} The bushing is not within spec like the factory piece {too fat,long,wide, etc...} B}Something else in the suspension is moving too much creating undue stress on it C} The material the bushing is made from is'nt up to the task.. And now for the factory authorized excuses.. You must have installed them wrong Your car have leaked something on it to make it fail like that.. Only poly on my street car builds are the sway bars anymore...I just don't need the headaches...Do they make the car handle better??? Of course they do but IMO they just don't hold up like the factory style material in the long run...
[Re: screamindriver]
#1451577
06/12/13 02:18 AM
06/12/13 02:18 AM
roe
Central TX
This one split and disintegrated. There may have been undue stress placed in it by the LCA. The poly bushing was allowing it to move fore and aft, even while loaded. I was replacing those with rubber in the next couple of weeks anyway, so I'll do them all at the same time.
roe
[Re: roe]
#1451578
06/12/13 11:28 AM
06/12/13 11:28 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
In my opinion, strut rod bushings should be rubber or heim joints. The way the strut rod/K-frame interface is constructed, the bushing must compress and de-compress with each up/down movement of the suspension. Poly is not compressible enough for this task. When using 6061 T6 aluminum strut rods, I observed flexing of the strut rod when used with poly bushings, but not with rubber bushings. I reccommend that you cancel the order for poly, and get rubber.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1451579
06/12/13 05:53 PM
06/12/13 05:53 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
This has happened in the AMC world too. Most would recommend rubber or heim's as well. AMC's have trailing arms with a bracket bolted to the frame. I've seen several failures most alarming have been the strut rod itself breaking and have also seen the frame bracket tear out of the frame.
Strut rods are designed to absorb some lateral force so they need to be able to flex. The rubber allows this.
I have not heard of any such failures on an AMC with the heim joints, but those are a relatively new item for us.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: Challenger 1]
#1451581
06/12/13 07:21 PM
06/12/13 07:21 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I agree also, poly is not the way to go because they don't last long, just like you found out.
At work, we years ago purchased 100's of upgraded/expensive polyurethane casters, they last for years, and then out of the blue, they all start to fail, and they seldom are used in the same conditions. Only reason we can figure is poly has a clicking clock time limit. All poly stuff on my cars has failed, some have never been on the road. I like poly, just don't expect a lifespan based on the amount/type of use.
I have asked this same question directed to Poly manufactures at PRI, all I got was a "dog look".
