Help Id this valve body... #1451405
06/11/13 07:43 PM
06/11/13 07:43 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Long story short- dropped the pan to swap out what was thought to be a swapped-in stocker. Looked identical to the Cheetah I was going to install except on the tab where the TA has "Cheetah" and "17156" hand-engraved, this one has "045" stamped through the plate. On the test drive the shifts were OK but discovered that it would shift automatically if left in drive. I'm stumped as the VB had no kick-down provision just like the Cheetah.
Not much to go on but it will be next Monday before I can swap out the VBs and try to find other markings.
Anyone familiar with this VB and can tell me what it is?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Help Id this valve body... [Re: I_bleed_MOPAR] #1451406
06/12/13 05:09 PM
06/12/13 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 045 stamping is the last three digits of the factory part number (in this case 3515045) of the steel plate used in various 727 valve bodies.
When you say the valve body "has no kickdown provision" do you mean the external lever? Even without the lever hooked up it will upshift automatically but not for very long...the linkage is essential for an automatic valve body.
Re: Help Id this valve body... [Re: John_Kunkel] #1451407
06/12/13 11:02 PM
06/12/13 11:02 PM
Buford, GA
Buford, GA
It has no lever on the side of the VB to move the valve (appears to be in a fixed position like the Cheetah). I wonder if someone tried to convert it manual?
Thanks, John, you answered my question that it's a factory VB (or at least started out that way ).
Tim
'71 Charger 383/727
