EDL Victor oil restrictor #1451296
06/11/13 03:28 PM
06/11/13 03:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made this jet from a welding wire tip drilled to .090 cuz I think my heads are flooded with oil and the sign was low oil pressure at 30# at idle and would raise when adding more rpm.
Re: EDL Victor oil restrictor [Re: Clanton] #1451297
06/11/13 03:31 PM
06/11/13 03:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Why would your heads be holding that much oil in them to require restriction? Do you have pushrod oiling to the rockers?
Re: EDL Victor oil restrictor [Re: Clanton] #1451298
06/11/13 03:32 PM
06/11/13 03:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
pics were too big sorry!here it is.
Re: EDL Victor oil restrictor [Re: BradH] #1451299
06/11/13 03:36 PM
06/11/13 03:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
no pr oiling but even my iron heads used a restrictor.when I primed the system a lot of oil was going up top.The cam is grooved for ful oil to heads also.
Re: EDL Victor oil restrictor [Re: Clanton] #1451300
06/11/13 03:43 PM
06/11/13 03:43 PM
BradH Offline
BradH  Offline
What rockers did you end up using w/ your new Victors?
Re: EDL Victor oil restrictor [Re: BradH] #1451301
06/11/13 03:45 PM
06/11/13 03:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have been using HS all along and just had to get the offset intakes.Here is the .090 jet in the head.
Re: EDL Victor oil restrictor [Re: Clanton] #1451302
06/11/13 03:48 PM
06/11/13 03:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I use some wire to hold guide the jet and slid it into place.
Re: EDL Victor oil restrictor [Re: Clanton] #1451303
06/11/13 05:59 PM
06/11/13 05:59 PM
BradH Offline
BradH  Offline
If you happen to make another couple of sets of those, send 'em my way. I'll be running Victors and a new roller w/ a full-groove #4 cam journal and might have some extra oil pooling up top, too, as a side effect.
Re: EDL Victor oil restrictor [Re: BradH] #1451304
06/11/13 09:56 PM
06/11/13 09:56 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
pm me your address or anyone else and a 5$ donation per set.Sorry I can not do it for free.
PS: these can fit stock iron heads also.
Re: EDL Victor oil restrictor [Re: Clanton] #1451305
06/15/13 07:31 PM
06/15/13 07:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
All fixed,I have 60+ psi with the drill using the restrictor.
Re: EDL Victor oil restrictor [Re: Clanton] #1451306
06/15/13 11:09 PM
06/15/13 11:09 PM
I used a set of .039 restrictors on my SR after trying .080(they have a set of T&D rockers though, not H.S. ), the World Blocks come with a .042 in the blocks
Re: EDL Victor oil restrictor [Re: Cab_Burge] #1451307
06/15/13 11:18 PM
06/15/13 11:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I just road coursed my BB and I can see where this would help me as well. Sucks during hi-G corners to have all your oil in the valve covers instead of the pan.
Mopar to the bone!!!
Re: EDL Victor oil restrictor [Re: 72Swinger] #1451308
06/15/13 11:31 PM
06/15/13 11:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I can only dream of cornering and I hope you are helped by my idea as well as others and no need to hide them in the block and swap them any time for another size.
Re: EDL Victor oil restrictor [Re: Clanton] #1451309
06/16/13 03:08 AM
06/16/13 03:08 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Have to do the same thing for my SB engine. Cam has grooves and lowish oil pressure.
The rockers sure get plenty of oil right now!
Nice use of used up stuff you had around the garage.
Re: EDL Victor oil restrictor [Re: RobX4406] #1451310
06/16/13 11:52 AM
06/16/13 11:52 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I had to buy a pack of welding tips at harbor freight so I used the leftovers[new].I posted this idea a couple months back but just now put it to use.
