Re: EDL Victor oil restrictor
[Re: BradH]
#1451299
06/11/13 03:36 PM
06/11/13 03:36 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Why would your heads be holding that much oil in them to require restriction? Do you have pushrod oiling to the rockers?
no pr oiling but even my iron heads used a restrictor.when I primed the system a lot of oil was going up top.The cam is grooved for ful oil to heads also.
[Re: BradH]
#1451304
06/11/13 09:56 PM
06/11/13 09:56 PM
Clanton
northern,Ohio,USA
pm me your address or anyone else and a 5$ donation per set.Sorry I can not do it for free. PS: these can fit stock iron heads also.
[Re: Clanton]
#1451306
06/15/13 11:09 PM
06/15/13 11:09 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1451307
06/15/13 11:18 PM
06/15/13 11:18 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I just road coursed my BB and I can see where this would help me as well. Sucks during hi-G corners to have all your oil in the valve covers instead of the pan.
Mopar to the bone!!!
[Re: RobX4406]
#1451310
06/16/13 11:52 AM
06/16/13 11:52 AM
Clanton
northern,Ohio,USA
Have to do the same thing for my SB engine. Cam has grooves and lowish oil pressure.
The rockers sure get plenty of oil right now!
Nice use of used up stuff you had around the garage.
I had to buy a pack of welding tips at harbor freight so I used the leftovers[new].I posted this idea a couple months back but just now put it to use.
